Old 11-15-2011, 09:51 AM   #1
quikoldawg
Default Reusable oil filter
Looking for feedback on the Professional Products billet reusable oil filter. Anyone using it and if so what are the pros and cons? No matter how hard I try it seems like I can't avoid spilling some oil on the headers when removing the filter. This looks like a better way...
Thanks in advance for your thoughts.
Scott
"If you can't find the time to do it right, when will you find the time to do it over?"
quikoldawg is offline   Reply With Quote
Old 11-15-2011, 10:49 AM   #2
John Dinkel
Liked 265 Times in 69 Posts
Default Re: Reusable oil filter
After looking at their site, it sounds like a hastle to clean the filter after every race.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-15-2011, 11:48 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Not big fan of professional products quality, if you want reusable filter spend a little more and get a System One filter.
Mike Taylor3601
Old 11-15-2011, 11:54 AM   #4
Liked 1,922 Times in 432 Posts
Professional Products is pretty much a company that makes Chinese knock offs of the products of other companies, with rather suspect quality. Not something I'd want on a race car, especially not in the oiling system of an engine.
Old 11-15-2011, 04:11 PM   #5
Ed Wright
Ed Wright's Avatar
Mike Taylor3601
There ya go!
Ed Wright 4156 SS/JA
Old 11-15-2011, 05:06 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
I use the System One filter. It is simple to remove and clean. real nice to check on the internals in the engine. no more cutting stock type filters. I lost 2 engines due to elcheapo AC filters. The internals in the filter colapsed and cut off the oil. No more regular filters for me. I highly recommend the System One filter.
Mike Pearson 2485 SS
Old 11-15-2011, 07:39 PM   #7
Mike Taylor 3601
For anyone who has never had filter collapse(spelling) the most usual sympton is oil pressure drops to about half of what engine normally holds then if you bring rpm up it goes to zero.
If using throw away use racing or hp type
Moroso makes a screen that lays in top of filter (chevrolet) there's another company that makes some for other applications can't think of brand name, but these screens work really well for keeping eye on engine without cutting filter apart.
They will show particles of stuff you will never see by cutting filter apart and inspecting,if you've ever used O'berg style filter they are like that, but just lay in top of spin on filter.
Mike Taylor 3601
Old 11-15-2011, 08:16 PM   #8
Run to Rund
Liked 55 Times in 28 Posts
Wix has a good reputation, and the 51258 that I use has a 19 micron filtration rating, 345 psi burst strength. What degree of filtration do the cleanable filters have?
Old 11-15-2011, 08:27 PM   #9
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Check this one out... Not the cheapest but seems to work great for me...
http://www.gopurepower.com/site/products/default.asp
Mack Reeves
2377 STOCK & SUPER STOCK
Old 11-15-2011, 08:38 PM   #10
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
I've been using these,almost exclusively since the early 70's.I've never had a an oiling issue.But then I've never owned one of those big money,high compression,high horsepower racing doohickey motors.
Also almost always used Pennzoil oil since before then.
Former NHRA #1945
Former IHRA #1945
T/SA
