Old 11-17-2011, 06:22 PM   #1
Dave1695
Liked 15 Times in 11 Posts
Default header tube size
Small block Chevy stocker engine, is there any advantage to using a1 3/4 to 17/8 inch step header over the smaller 1 5/8 to 1 3/4 inch step?
Dave1695 is offline   Reply With Quote
Old 11-17-2011, 06:25 PM   #2
Jim Kaekel
Liked 540 Times in 112 Posts
Default Re: header tube size
Probably going to need more information. Displacement? Carbureted or EFI? Compression ratio? RPM range? Car type & weight, etc., etc., etc.,
Jim Kaekel 3836 STK
Old 11-17-2011, 07:06 PM   #3
Liked 1,954 Times in 440 Posts
That would be a question for PipeMax software, Jere Stahl, or Calvin Elston (who will tell you that you need 4-2-1 or tri-y headers). I'd need a detailed sheet on the engine to give you a good idea what it wants.
Old 11-18-2011, 01:24 PM   #4
Dave1695
The engine is .040 over 350, 10.5 comp. 750 dbl pump on victor jr, car weight 3100. running in IHRA Crate Motor class. Trap RPM 7200. I have always thought the pipe at head should be approx. the same size as exhaust valve but have gotten some opinions that the larger 1 3/4 inch pipe at head works better. The 4-2-1 collector is pricey but have heard well worth the investment. Thanks for your input gentleman.
Old 11-18-2011, 05:18 PM   #5
Greg Hill
Liked 279 Times in 68 Posts
That motor is comparable to the motor in my car and my stahl headers are1 3/4 to 1 7/8 with a 3" collector. With a tri Y it's a whole different deal.
Greg Hill 4171 STK
Old 11-19-2011, 03:09 AM   #6
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Dave I have had the 4-2-1 collectors & Merge both on my car......Same E.T. out of both. I would go with the 1 5/8 step to 1 3/4........unless your running the Fast Burn heads.
Old 11-19-2011, 12:38 PM   #7
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
1 5/8...............
Bob Bender 144 O/SA
Old 11-19-2011, 01:21 PM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: header tube size
Several IHRA and NHRA 360 Stockers, including myself, use off the shelf TTI 1 5/8"-1 3/4" step headers with good results. But they only manufacture Mopar applications.
Old 11-19-2011, 08:48 PM   #9
K Stubbs
Liked 20 Times in 3 Posts
Whatever Greg Hill is running.
K Stubbs is offline   Reply With Quote
Old 11-20-2011, 12:48 PM   #10
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Either size will work well on a 350. Don't fall into the "equal length" trap. Just buy a merge collector from Performance Welding. The larger header may want to be shorter on the primaries. If you don't buy a merge collector, consider buying or building a header that fires in rotation into the old style collector. But, the bottom line is, it's all theory until you get an ET slip........
Wade O
