Old 11-19-2011, 07:47 PM   #1
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Question BBC Edelbrock Intakes??
I am restoring a 66 Chevelle street/strip toy.I have to run a q-jet or my buddies will raz the heck out of me LOL.looking at the air gap vs traditional intake.With the air gap we have to run an adapter but the traditional RPM has a Q-Jet bolt pattern.My question is do you think the air gap will show any HP over the regular RPM style.Thank in advance
Performer RPM 2-O Q-Jet (oval-port, non-EGR) #7164*
Carburetor Recommendations: Edelbrock Thunder Series AVS or Performer Series carb, 650-800 cfm (see Carbs & Accessories), use bracket #8031 for 1972-78
Installation Notes: Recommended intake gasket: Edelbrock #7203. Manifold height: A-4.45", B-6.0" see A/B Measurements. Port exit dimensions: 1.61" x 1.93". For divorced choke use #9178.
Chevrolet 396-502 V8
RPM AIR-GAP 2-O (1500-6500 rpm)
Designed for street 396-502 c.i.d. Chevy V8s with large oval-port cylinder heads (1975 and earlier), the new RPM Air-Gap incorporates the same race-winning technology that's been used on our Victor Series competition intakes for years.The air-gap design features an open air space that separates the runners from the hot engine oil resulting in a cooler, denser charge for more power. Includes rear water outlets, two distributor clamp locations and nitrous bosses. Accepts all late model alternator and A/C brackets for the street. For square bore carburetors only. No provision for exhaust heated chokes and no exhaust crossover. Will not fit under stock hood of Corvette, 1965-67 Chevelle or 1967-81 Camaro. Available with standard finish, polished, EnduraShine finish or black powder coated NASCAR Edtion for a look you've got to see to believe, Recommended intake gasket: Edelbrock #7203. Manifold ht.: A-4.45", B-6.0" see A/B Measurements. Port exit dimensions: 1.60" x 1.94".
Old 11-20-2011, 12:20 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: BBC Edelbrock Intakes??
wasn't worth any ET when I made the same swap years ago on my pump gas ~ 650 HP 468...
Old 11-20-2011, 12:01 PM   #3
Ron Miller
Liked 13 Times in 7 Posts
Kevin,
Did you have any luck finding a New Weiand Team G Oval Port intake ?? Have you look at a Brodix HV 2007 for your project ?
Ron
Ron Miller is offline   Reply With Quote
Old 11-20-2011, 12:26 PM   #4
SSGN
SSGN's Avatar
Talking Re: BBC Edelbrock Intakes??
We found a brand new one and it was good to us.I will have to look at the Brodix,thanks again
Kevin
Old 11-20-2011, 12:31 PM   #5
SSGN
SSGN's Avatar
Damn that is nice! Did all your stuff fit under stock hood?I am not a fan of aftermarket hoods,kinda like the stocker look.Thanks for the pics
Kevin
Old 11-20-2011, 02:03 PM   #6
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I think you'll get more hood clearance w the non air gap. 68 Chevelles and up had more clearance I believe compared to 67 down.
Ed's engine fit under the stock hood, seen it many times, was a real nice ride.
chris ok is offline   Reply With Quote
Old 11-20-2011, 06:19 PM   #7
Ron Miller
Kevin
Did you buy the one that was for sale on YellowBullet a month back ??
Old 11-24-2011, 08:12 AM   #8
1320racer
1320racer's Avatar
Kevin
Yes...
