Old 11-22-2011, 11:30 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Drum Brakes
Is there a company that makes brake shoes for racing? I'd like to put primary shoes everywhere with good lining material.
Ron Gusack is offline   Reply With Quote
Old 11-22-2011, 11:54 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Drum Brakes
I had good luck with premium ABEX organic linings on stock shoes from Ott's Friction Supply in Oregon, contact:
john andreotti <andreotti@ottsfrictionsupply.com>
I also have a set of the Velvetouch linings I bought 30-some years ago, but they don't work so well until heated up, so the line lock doesn't do much. . .
Old 11-22-2011, 12:27 PM   #3
I would think you would want to put secondary shoes everywhere. Drum brakes retract so there's no drag anyway.. $.02
Old 11-22-2011, 12:31 PM   #4
FED 387
Liked 333 Times in 180 Posts
see if you can find a reliner that does metallic brake shoes---they do not work cold but stopping at the top end is improved the hotter they get the better they work
Old 11-22-2011, 12:37 PM   #5
FED 387
try CTbrakes.com they can reline your shoes ---about $75 per axle thats what they are quoting now---might be more but give em a call--
Old 11-22-2011, 12:41 PM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
I run drums all the way around and I've had pretty good luck with Raybestos riveted shoes. I noticed that when I removed weight to move from E to D/SA, my car stopped a fair amount better even though it's only about 175 lbs. lighter. I would not recommend using aluminum drums since I developed cracks in mine and went back to cast iron. My .02.
Jim Kaekel 3836 STK
Old 11-22-2011, 02:16 PM   #7
Ron Gusack
Ron Gusack's Avatar
Thanks for the replies. This is a foot brake car and sometimes it pushes the car forward when I'm staged and the rpm's are too high. I sometimes run an index class with a .400 pro tree and I need the R's pretty high. I'm thinking the extra primary shoes would help to hold it better.
Old 11-22-2011, 02:55 PM   #8
njk53
I remember Car Craft or Hot Rod Magazine did an article on a brake manufacturer out of Texas that made a brake shoe with 30% better stopping power than a normal brake shoe. Just can't think of the name of the company.
Nelson Kowal
Stock 345
Old 11-22-2011, 03:44 PM   #9
Jim Kaekel
Check shoe adjustment. I run my fairly loose for reduced brake drag, but that will happen if they get too loose.
Jim Kaekel 3836 STK
Old 11-22-2011, 04:21 PM   #10
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
The primary or leading shoe is the shorter shoe and the secondary or trailing shoe is the longer shoe.........
Bob Mulry 7516 STK
A & M Motorsports
