Old 11-21-2011, 06:34 PM   #21
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Unhappy Re: header tube size
BOY! You said it !
I've got a bunch of expensive stuff I'm gonna make into wind chimes and try to sell on E-BAY.
"Tune around what you have" is the best advice I ever got.
KISS method.........
Originally Posted by Wade_Owens View Post
Lol, I've wasted enough money on headers and hardly ever see a gain. Use the KISS method.........
Wade O
MEXJOE is offline   Reply With Quote
Old 11-21-2011, 08:07 PM   #22
chassis1
Liked 9 Times in 3 Posts
Default Re: header tube size
everyone seems to forget that the cam is still the brain of this deal when it comes to headers. most of the time, off the shelf STOCKER cams are still very old designs and are not made to be as efficient as some headers are built or bought, no matter what your engine guys chooses.....truth is most engine guys miss on the cam and go to what they call, " ol' reliable cams...." but yet the racer seems to think better than the engine builder sometimes...and looks at his WHOLE combination......
Chassis1
chassis1 is offline   Reply With Quote
Old 11-22-2011, 12:44 AM   #23
K Stubbs
Liked 20 Times in 3 Posts
I know a racer that ran a 69 Camaro 350/255 auto stocker. He had a set of Kromer (sp?) step headers that were 1/12 - 1/58 - 13/4. He blew out a tube at a race and put on a straight 13/4 on that side and did not affect performance one bit. He ran it like this for a couple of years and won class many times including Indy. Like Wade said, unless you are way out in left field there is probably not a big performance difference in them.
K Stubbs is offline   Reply With Quote
Old 11-22-2011, 10:24 AM   #24
Charlie Yannetti
Liked 192 Times in 83 Posts
Not for nothin', Dave.. but I would be looking to talk to Billy Nees on this issue.. he will put you in the right direction, and/or build you a set..
Charlie Yannetti is offline   Reply With Quote
Old 11-22-2011, 11:26 AM   #25
MEXJOE
MEXJOE's Avatar
Thumbs up Re: header tube size
I would just call this guy.!
http://www.perfweldheaders.com/
Take a look at the E/SA & F/SA RECORDS!
He builds nice quality stuff and he is not a liar & HIS stuff fits and WORKS!
Old 11-22-2011, 01:12 PM   #26
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
X2, If he can help, he will. If he cant improve upon what you have, he will tell you that also.
and his car is bad fast!
Wade O
Old 11-22-2011, 06:25 PM   #27
Dave1695
Liked 15 Times in 11 Posts
Lots of great advise guys, thank you. I'll talk to all the recommended sources for sure. I plan on installing a new cam, so the header change can be done after a new base line is established. I was pretty sure the first pipe should be close to exhaust port size but had not considered a three step header. My combination runs under the index everywhere and I'm usually in the late rounds but you know how it is in Stock Eliminator, there is always room for improvement.
Dave1695 is offline   Reply With Quote
Old 11-22-2011, 06:50 PM   #28
Liked 1,892 Times in 423 Posts
Step headers offer a small gain, mostly what they do is increase average HP and torque. It is critical that the length of the primary and collector tubes is correct. You can actually get away with as large or larger an error in diameter than you can in length. A two step header (3 diameters) is worth just a few percent in peak power, but can be worth more in average power.
Old 11-22-2011, 08:21 PM   #29
5343stk
5343stk's Avatar
Mark builds the best header I have used. They are a work of art. They fit without having to bust out the hammer. His customer service is second to none.
Keep in mind, there is a common denominator in our cars besides the headers. There is a gentleman in Missouri that seems to know his way around stock eliminator engines. I wish my car was as quick as his.
James & Kari Findell
(2) 1973 Plymouth Duster's 340
NHRA Stock Eliminator
5343stk is offline   Reply With Quote
Old 11-22-2011, 08:51 PM   #30
Wade_Owens
Wade_Owens's Avatar
You are so right. Brad is aces on those small block Mopars!
