Old 11-23-2011, 03:38 PM   #71
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default Re: 2012 Rules Are Posted
Wow, parked the stocker for 3 years and it's amazing how far behind I am now. I have been gathering up to date parts to put it back together and the list keeps growing.
Now I need a aftermarket block,and roller rockers, enough already.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 11-23-2011, 03:44 PM   #72
7423
[QUOTE=Alan Roehrich;295110]That rule changed. They removed : Aftermarket rocker arm must be identical to OEM so there is no longer a written rule saying the OEM ratio must be retained. The part listed in red above is what required the OEM ratio.
The legal rocker ratio for your combo has always been listed on the engine blueprint sheets. The VERY unclear new rule states you may now use roller rockers. Doesn't say you may now change your rocker ratio.
I think the only thing this new rule has created is more drama...................
7423 is offline   Reply With Quote
Old 11-23-2011, 04:53 PM   #73
Tony Janes
Monte you do not need a after market block or roller rockers. You need 3 speed transmission.
Tony Janes 7941 STK, SS
Old 11-23-2011, 08:37 PM   #74
Liked 1,892 Times in 423 Posts
[QUOTE=7423;295118]
I'm well aware of where the rocker arm ratio has been listed.
The new unclear rule does not say anything about your new aftermarket racing roller rocker arms being identical to the OEM rocker arms they replace, anymore, either.
Old 11-23-2011, 09:06 PM   #75
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
Originally Posted by vic guilmino View Post
i do not see anything about roller rockers
it says rocker arm are not roller rocker arm
I agree, I was understood roller rockers were ok but it does not say that ???
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 11-23-2011, 09:35 PM   #76
ZenzenRacing
Liked 53 Times in 17 Posts
Cool Re: 2012 Rules Are Posted
Sorry if I missed it. Window nets, ribbon type, new one with a date ? If so, wonder what the market is for 3yr old ribbon ones.
ZenzenRacing is offline   Reply With Quote
Old 11-23-2011, 11:32 PM   #77
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Too bad the clowns in Glendora don't have an expiration date.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 11-24-2011, 02:02 AM   #78
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Originally Posted by ed fernandez View Post
too bad the clowns in glendora don't have an expiration date.
"like"
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 11-24-2011, 03:22 AM   #79
SS Engine Guy
A more detailed explaination will be added in the future.
With the amont of sentences detailing how I can't use mouth wash in the morning or I might be booted and fined I would think that adding the words "stock mounting and stock ratio will still apply" wouldn't be too hard to have inserted in this great document..
When reading the rule book I find that if you play by what it says you are two years behind. Its what it dosen't say that is the mystery.
SS Engine Guy is offline   Reply With Quote
Old 11-24-2011, 09:38 AM   #80
james schaechter
Talking Re: 2012 Rules Are Posted
Monte, why jack around with a 2 or 3 speed.
Just put a 4 speed in! It is a heck of alot more fun!
James Schaechter 3163 STK
