Old 11-25-2011, 08:40 AM   #1
R. Thorne
Liked 101 Times in 34 Posts
Default roller rockers
It seems like a lot of racers don't want roller rockers (myself included). Write NHRA, tell them and while you're at it, suggest a max valve spring pressure (say, 300-350lbs open) . No more rocker arm issues, lifter problems, pushrod flexing, more square lobes (no advantage without additional pressure) , rpm range kept "reasonable", etc. It has worked before (mufflers). Ron.
R. Thorne is offline   Reply With Quote
Old 11-25-2011, 09:32 AM   #2
Crew Chief
Liked 10 Times in 6 Posts
Default Re: roller rockers
Ron, You are partly correct. Not all racers wanted roller rockers. The ones that really wanted them are the ones who chose to race a combination that has a poor valve train set up. They kept bending the ear of select officials until......well you see what we now have.
Unlike roller rockers, the muffler issue never became a rule. Once a rule is printed, manufacturers fill their bins and racers spend cash on parts, it is hard to get a ruling reversed.
Speaking of roller rockers in Stock now being allowed...why would anyone think that any ratio other than stock would be allowed? Be ready to have the ratio checked in a teardown.
Crew Chief is offline   Reply With Quote
Old 11-25-2011, 11:35 AM   #3
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
It is my understanding stock racers will not be forced to use roller rockers. I.H.R.A has allowed Roller Rockers for years before N.H.R.A. This issue is simple to resolve. If you do not like the new rule, just use what you have been using, it is just that simple.
I for one will use the roller rockers. Not because of a performance davantage, i will use them because of a reliability factor and for no other reason.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 11-25-2011, 12:02 PM   #4
7423
Roller rockers will only cause more breakage and oil downs, ( then will come a diaper rule). I am not in favor of the rule change, wish the money hungry bunch in Glendora would leave well enough alone.
How about a rule that would help the life of this sport? Something that would allow the next generation to enjoy drag racing.
Something that would keep the neighbors happy and make the tree huggers smile.
Put mufflers on your car and save a drag strip, maybe that would have saved my local track.
7423 is offline   Reply With Quote
Old 11-25-2011, 02:32 PM   #5
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
So true Charlie !
So many tracks are getting shut down by the noise complainers.
It's 100 times easier to shut a track down than to open one up.
I run mufflers on all my cars, regardless of how much power they make. There's actually mufflers out there now that will help make more power with certain combos.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 11-26-2011, 06:22 PM   #6
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Wink Re: roller rockers
IHRA also allows after market intakes and carbs on their cars,HMMMMMMMMMMMM maybe that is coming next to the new class "stock appearing" We have stockers with 14 inch hi intakes,carbon fibre parts etc.Why stop their,think of the aftermarket and how it could drive the economy
Kevin
Old 11-26-2011, 09:21 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: roller rockers
Kevin
IHRA only allows readily available and unmodified aftermarket intakes and certain unmodified Holley carbs with choke plates on approved Crate Motor combinations. Not all factory crate engines have intakes and most, if not all, don't have carbs. Aside from that, they have blueprint specs to follow just like "regular" Stockers.
The new factory race cars are a totally different situation, which, ironically, are even further from "Stock" than any IHRA Crate Motor combo!
Old 11-27-2011, 03:36 PM   #8
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: roller rockers
Also, the "regular" IHRA Stockers (non-crate) follow the same rules as the NHRA Stockers with the exception of the 10" tire. They have allowed roller rockers for several years. Jim
Jim Wahl is online now   Reply With Quote
Old 11-27-2011, 03:55 PM   #9
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Originally Posted by Jim Wahl View Post
Also, the "regular" IHRA Stockers (non-crate) follow the same rules as the NHRA Stockers with the exception of the 10" tire. Jim
Not really true.
NHRA has an accepted rod list where aftermarket rods must meet specifications on the then-current NHRA Stock and Super Stock Replacement Rod Acceptance List.
IHRA says you can run "Super Stock connecting rods in Stock Eliminator."
They really don't provide any specifications to go by for rods or pistons.
Old 11-27-2011, 04:14 PM   #10
Jim Wahl
Jim Wahl's Avatar
Question Re: roller rockers
Originally Posted by 442OLDS View Post
Not really true.
Interesting. My answer to questions such as that has always been "if not IHRA specified use NHRA spec". Jim
