Old 12-01-2011, 06:47 PM   #1
Stocker 2
Default Is this legal?
I was told I could use an anti-rollbar on the rearend in stock but it had to be a bolt-in unit.
Is it legal to weld in box tubing for mounting the anti-rollbar?
Check out this installation:
http://www.competitionplus.com/drag-...via-suspension
Stocker 2 is offline   Reply With Quote
Old 12-01-2011, 08:42 PM   #2
fredjohnston
Liked 55 Times in 14 Posts
Default Re: Is this legal?
looks bogus to me. If I was from that area I would protest.
fredjohnston is offline   Reply With Quote
Old 12-01-2011, 09:04 PM   #3
Notch1320
And the "rule book" says what about anit roll bars???
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 12-01-2011, 10:22 PM   #4
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
ahhh...I think it says nothing....traction devices are "supposed " to be bolt on, anti-roll bar is not a traction bar, I've looked under many stockers,lots have them and all were welded in.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 12-01-2011, 11:13 PM   #5
Notch1320
^^^ Yep! Mine is welded in.
Shawn Allsup
K/S 718
Old 12-02-2011, 01:40 AM   #6
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
You can tack weld the anti roll bar in place and bolt it, but i was told you could not completely weld the unit in. Thats the way mine is put it, works great and never had a issue.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 12-02-2011, 08:37 AM   #7
Billy Nees
Liked 7,925 Times in 1,760 Posts
OK, if it's not a traction device then what exactly is it? Why do you have it in the car?
To answer the question, no it's not legal but all of the late model F bodies that I've looked at have them welded in and the particular kit in that article is meant to be welded in.
NHRA should spend some time looking under cars instead of just looking under hoods.
Billy Nees 1188 STK, SS
Old 12-02-2011, 09:54 AM   #8
Chad Rhodes
well the rule book says you can "beef up" the frame, and the anti roll bar is technically bolted to what ever extra "bracing" they added
Chad Rhodes 2113 I/SA
Old 12-02-2011, 10:11 AM   #9
Billy Nees
I can't find that one. Could you please point out where that is in the book?
Old 12-02-2011, 10:17 AM   #10
Stocker 2
The frame can be "beefed up" in stock?
I looked for that in the rulebook before I asked the question. I did not see any such statement in the stock section. The only allowable addition I can find is the connectors between front and rear subframes.
