Old 12-02-2011, 06:39 PM   #21
BBF67
Liked 8 Times in 4 Posts
Default Re: Is this legal?
ahhh...I think it says nothing....traction devices are "supposed " to be bolt on, anti-roll bar is not a traction bar, I've looked under many stockers,lots have them and all were welded in.
Just ask Robert Pond if an anti-roll bar is considered a traction device. From what I have been told he had to move his from inside the trunk to under the car. At that time NHRA ruled it as a traction device and said he could continue using it as long as it was bolted in. I do believe the brackets can be welded to the rearend housing but thats all.
BBF67 is offline   Reply With Quote
Old 12-02-2011, 06:42 PM   #22
Jeff Swanson
Liked 62 Times in 21 Posts
I went to a lot of trouble back in the day to put an anti-roll bar in my car and make it 100% bolt in. Worked like a champ but definitely would have been easier to weld it in.
Jeff Swanson is offline   Reply With Quote
Old 12-02-2011, 08:45 PM   #23
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
If the "weld on" style are legal, I'll be changing mine over. I have some issues with my bolt on system, some welding would correct these problems.
Wade
Old 12-02-2011, 09:37 PM   #24
Tom Rix
Here's one that is 100% bolt on and used by several Stockers and even some 9"tire SS. It works!
http://www.hrpartsandstuff.com/produ...nd/swaybar.htm
Tom
Tom Rix is offline   Reply With Quote
Old 12-02-2011, 09:48 PM   #25
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Talking Re: Is this legal?
Tom
Yup and 8 second Turbo Buicks,his stuff is pure art.
Kevin
Old 12-02-2011, 10:15 PM   #26
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
No sir.
care to explain the differance?
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-02-2011, 10:37 PM   #27
Ed Wright
Ed Wright's Avatar
Sway bar = panhard bar. Locates the rear end side-to-side. Anti-roll bars control body roll. Two separate components. Body roll & side-to-side sway are two different things.
At least that's according to GM shop manuals.
Ed Wright 4156 SS/JA
Old 12-02-2011, 10:42 PM   #28
Notch1320
And still... no one can post where the rule book states that you CAN'T weld in an anti-roll bar......
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 12-02-2011, 10:52 PM   #29
Mark Markow
i'm not looking for an argument but, i guess i'll have to disagree with gm on that one . how in the world a (sway bar = a panhard rod) is beyond me. i guess a camaro with a front sway locates the front end? LOL. in my opinion a sway bar and a anti roll bar are the exact same thing. they both control body roll. i guess technically it should be called an anti-swaybar
Mark Markow
171 ss/tb
Old 12-02-2011, 11:03 PM   #30
Ed Wright
Ed Wright's Avatar
Mark, sway is side-to-side. A panhard bar locates/centers the rear end under the car side-to-side, but will not control body roll.
That front bar is anti-roll also.
