Old 12-04-2011, 08:50 AM   #41
Billy Nees
Liked 7,898 Times in 1,754 Posts
Default Re: Is this legal?
Originally Posted by nolongerracing View Post
So if it came with an anti-roll, why can't it be replaced with an aftermarket unit?
It can be replaced with an aftermarket unit but the aftermarket unit can't be welded in!
Billy Nees 1188 STK, SS
Old 12-04-2011, 09:28 AM   #42
Chris1529
Liked 70 Times in 29 Posts
Originally Posted by Jeff Swanson View Post
I went to a lot of trouble back in the day to put an anti-roll bar in my car and make it 100% bolt in. Worked like a champ but definitely would have been easier to weld it in.
Jeff, what brand of bar did you start with?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 12-04-2011, 01:01 PM   #43
Jeff Swanson
Liked 62 Times in 21 Posts
Chris, it was originally a MidSouth Race Cars piece. Not sure if they're still in business or not, but you could do the same with any Mustang anti-roll bar.
Jeff Swanson is offline   Reply With Quote
Old 12-04-2011, 01:09 PM   #44
Ed Wright
Ed Wright's Avatar
Anti-roll, anti-sway or stabilizer (according to GM parts) are all the same. The purpose of the panhard bar (axel tie rod according to GM parts) is to only keep the housing centered in the car. It is not a side to side "sway bar". So if it came with an anti-roll, why can't it be replaced with an aftermarket unit?
Take that sucker off and see if you can't push the car side-to-side without the tires moving. That is sway. As I said before, accurate or not, go ahead and call it what you want.
Ed Wright 4156 SS/JA
Old 12-04-2011, 04:01 PM   #45
Stocker 2
Cars such as a coil spring Mustang or Chevelle do not use a panhard arm because the rear control arms are set at an angle to the centerline of the car. The angle of those control arms stop any sway. Any coil spring car that has the control arms running almost straight forward needs a panhard arm to stop the body from swaying sideways and keep the rearend centered under the car.
Both type setups can take advantage of an "added" anti-rollbar which stops the body from rolling or torqueing over on the suspension. Lately a lot of coil spring GM cars like the Chevelle, GTO, GS Buick, etc have bolted a large tube between the lower control arms tying them together. This is a beefier takeoff on the factory bar that was on the some of the original performance cars. I was told this setup is accepted because it bolts to the lower control arms.
Stocker 2 is offline   Reply With Quote
Old 12-04-2011, 08:40 PM   #46
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I can't take it anymore.......
Panhard bar = poor man's watts link and is ONLY used to latterly locate the rear end housing under the car.......
Sway bar = anti-roll bar = stabilizer bar and it is ONLY used to control body roll by applying pressure across the vehicle.....The body wants to roll but because the bar is attached to the body and the links try to twist the bar to roll.......In some types of racing the racers like to have the links adjustable to pre-load the suspension with out changing the spring rate.......
Same thing with the "anti-sway bars = anti-roll bars = stabilizer bars" that bolt solidly to the lower control arms. The bar will always attempt to keep the control arms parallel and prevent body roll....
Bob Mulry 7516 STK
A & M Motorsports
Old 12-04-2011, 10:18 PM   #47
Notch1320
Originally Posted by stk4178 View Post
I just sent a question to tech tto see what they say about this subject
Please keep us posted on what the tech folks say on this subject....
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 12-04-2011, 10:35 PM   #48
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
i think neveryone but Ed will agree with you, i have never heard a panhard rod called a sway bar,
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-05-2011, 12:01 AM   #49
J&P
Talking Re: Is this legal?
Anti-roll bar = Sway bar ... Check out Jegs an Summit and look for Panhard bar end links. They have them for Sway bars , but, I don't think you will get them to work with a Panhard bar...
Anti roll-bar / Sway-bar controls body roll or Sway
Panhard bar / Diagonal / wishbone / Watts link control lateral movement
Jus sayin.....Pete
J&P is offline   Reply With Quote
Old 12-05-2011, 02:08 AM   #50
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Wink Re: Is this legal?
I can't take it anymore...........
HEEE HAAA HEEE !
Was wondering when someone would finally say that !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
