Old 12-12-2011, 08:54 PM   #1
BillK
Liked 30 Times in 17 Posts
Default IHRA Engine Blueprint Specs ????
Hey guys,
Am I just being blind, or does IHRA not have blueprint specs on thier website like NHRA does ???
Bill Koustenis
BillK is offline   Reply With Quote
Old 12-12-2011, 09:12 PM   #2
Chris1529
Liked 70 Times in 29 Posts
Default Re: IHRA Engine Blueprint Specs ????
use NHRA specs except for Crate motors which are listed on IHRA. A few other exceptions as well such as can run an automatic in a car that originally was manual only, some different carbs allowed, etc. If you have a question about a specific spec, call them.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 12-12-2011, 09:33 PM   #3
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Thats not really true according to the IHRA rulebook.
Super Stock connecting rods are legal in Stock Eliminator in IHRA.Not so in NHRA.
Old 12-13-2011, 10:23 AM   #4
Chris1529
Since NHRA publishes a list of acceptable stock/superstock replacement rods, I figure most professional engine builders go with one that is on the list for a given combination.
If someone builds two identical engines, with the exception of stock legal rods in one, and superstock legal rods in the other, how much performance gain could be expected?
Chris Bowman
1984 Mustang GT350
Old 12-13-2011, 11:12 AM   #5
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Maybe try this. I haven't looked at it all, but it might offer some help.
http://www.ihra.com/ClassRacing/
http://www.ihra.com/CompetitionGeneral/
http://www.ihra.com/ContactUs/
Old 12-13-2011, 10:27 PM   #6
442OLDS
442OLDS's Avatar
Its not just the rods,its also the pistons:
Only the top (combustion chamber side) of the piston has to "LOOK" correct when viewed from an assembled short block. The dish/dome still have to measure correct. They dont care what it is like below the deck (moved rings, thinner ring pack, lite pins, lite pistons, valve relief location and depth, etc.).
Performance gain?
I would think the IHRA car could beat the NHRA car in a heads up!
Old 12-14-2011, 09:15 AM   #7
Chris1529
This is just my guess, but I figure the majority of people building or running a regular stocker in IHRA can or do run it in NHRA as well. I don't think there are too many purpose built IHRA regular stockers.
Chris Bowman
1984 Mustang GT350
Old 12-14-2011, 09:59 AM   #8
NewHemi
NewHemi's Avatar
I talked to Mike Baker the other day about this, and he said that the NHRA specs which are posted on the NHRA site, are what is used. But because they are copyrighted material, he just points forlks to them, rather than simply copy them to the IHRA website which would be wrong to do.
But those specs pretty much apply.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 12-14-2011, 11:49 AM   #9
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Only the top (combustion chamber side) of the piston has to "LOOK" correct when viewed from an assembled short block. The dish/dome still have to measure correct. They don't care what it is like below the deck (moved rings, thinner ring pack, lite pins, lite pistons, valve relief location and depth, etc.).
Maybe I'm missing something here, but part of the engine specifications are piston, piston ring and pin weights. So other than having a certified replacement piston (published by manufacturer/part number) as listed in the guide, you can't modify them, at least in Stock Eliminator.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 12-14-2011, 02:23 PM   #10
Chris1529
Lew
Thats what I thought.
Chris Bowman
1984 Mustang GT350
