Liked 2 Times in 1 Post
1966 3869942 427 4 bolt block stanard bore with original pistons & rods $4000
1967 3919840 heads rebuilt E-24-7 & F-7-7 ported wtih overiszed valves $2000 1967 3904391 single stock head rebuilt dated C-15-7 $1750 1967 3904391 heads both dated J-10-6 ported with oversized valves $1750 1967 3885069 aluminum intake 6-27-67 with center plenum cut out $300 1968 3919840 single stock head rebuilt dated E-8-8 with 1.88 valves $850 1968 3919840 heads L-21-7 & D-23-8 bare and ported with 1.88 valves $850 1968 3933163 aluminum intake 3-20-68 with small weld repair on topside $300 1969 3919840 heads rebuilt and stock with 2.25 intake valves modified only $1750 1969 3955272 396 4 bolt fresh 30 over with new cam bearings & freeze plugs $1750 6223 steel crankshaft standard balanced to new keith black 30 over 396 pistons mounted to stock GM rods $600 6223 steel crankshaft turned 20 under ready to go $300 1969 8 inch timing cover $150 1969 8 inch factory balancer $150 7/16 dimple rods $250 330-770-2517 for any questions or pictures needed. Can ship if you cannot pick up. |
Liked 203 Times in 52 Posts
