Old 12-19-2011, 03:04 PM   #1
Tgreen3724
Default Lightweight Crank vs. Cast
What do you guys think the potential HP gains are for a lightweight vs. cast crank in a BBC? Just trying to get my monies worth this winter
Tgreen3724 is offline   Reply With Quote
Old 12-19-2011, 08:42 PM   #2
Liked 1,908 Times in 427 Posts
Default Re: Lightweight Crank vs. Cast
I know guys going fast with cast cranks, but most, if not all of them, replace those things regularly (some as often as every 50 passes). I suppose that's okay if you have money and can afford the risks. Not something I'd suggest if you're trying to mind your budget, I advise my customers against it.
Old 12-19-2011, 11:10 PM   #3
tj310
Alan's right, I believe a stock cast BBC crank is lighter than a stock forged crank. Lightweight aftermarket cranks are not legal in stock or SS. --- Trevor
Old 12-20-2011, 01:02 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
The lightweght vs heavy is something I have worked with many of my circle track customers. There is no HP there in steady state or controled rate dyno tests. All you get is better acceleration rate.
Ouicker under load. In a drag car that is the initial pull off the line and at each gear change it accelerates quicker. Liteweight rotating mass is quicker down the track, no more HP. Use the cast crank in your stocker r SS. As noted in previous posts aftermarket cranks are not legal in S/SS.
Adger Smith (Former SS)
Old 12-20-2011, 03:28 AM   #5
Ryan_Haag
Ryan_Haag's Avatar
Liked 8 Times in 3 Posts
A cast crank is around 10 lbs. lighter than a steel crank, but a cast crank may get 50 runs. Cast cranks on the other hand don't break in half, they just start cracking and slow down about a tenth each pass. Been then done that! By then time you invest money into an old cast or steel crank, spend the extra money and buy an aftermarket Callies crank. Lighter, better, and faster. If you use the lightest one, its around a tenth on the track just to acceleration. Just my two cents.
Ryan Haag
SS/EA 3750
E/SA 3750
Ryan_Haag is offline   Reply With Quote
Old 12-20-2011, 03:37 AM   #6
Ryan_Haag
Ryan_Haag's Avatar
Aftermarket are allowed in super stock.
Ryan Haag
SS/EA 3750
E/SA 3750
Old 12-20-2011, 09:11 AM   #7
Tgreen3724
Thanks to all the input.
Old 12-20-2011, 01:24 PM   #8
eddie c
Correct me if I am wrong, I remember quite a few years back that
Lunatti sold a crank that I think was legal in Stock. Now possibly they
were using a stock crank and massaging it to get a little more power,
does anyone recall this? ed
eddie c is offline   Reply With Quote
Old 12-20-2011, 02:02 PM   #9
Lunati once specialized in Stock and Super Stock cranks and cams. Yes, they had a line of "race prepped" OEM forgings and castings.
There are some former Lunati people at Bullet doing crankshaft work, they offer the same services once offered by Lunati.
Old 12-21-2011, 03:42 PM   #10
Woodro Josey
Liked 3 Times in 1 Post
I have used Bullet cams and i send my Cranks to them,those guys do a great job and Alan is right, some of the Lunati Crank guys are at Bullet!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
