Old 12-18-2011, 05:19 PM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Q-jet and Holley
Get the turbine off!!!, put in a fresh set of plugs and tune by reading the plugs.
Remember: It would be correct to assume the Holley told you the engine was in mechanical sound condition. Those Holley EGT's were not out of the ballpark. Don't just chase anything & everything. Don't do needless changes.
Adger Smith (Former SS)
Old 12-18-2011, 09:27 PM   #12
Darrin Christen
Darrin Christen's Avatar
What is a top hat or turbine? Is this something used on the dyno only?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 12-18-2011, 09:50 PM   #13
Weekend Racer
Darren,Yes the turbine is only dyno supply air from outside
Thank!
Weekend Racer is offline   Reply With Quote
Old 12-18-2011, 09:57 PM   #14
Mickey Whaley
Question Re: Q-jet and Holley
Originally Posted by Weekend Racer View Post
Chevy small block 350,make 597 hp with holley 750, and drop to 562 with Q-Jet .What can I do?
Any input Thank,
why did you take the 750 off??
Mickey Whaley is offline   Reply With Quote
Old 12-18-2011, 10:03 PM   #15
Weekend Racer
Mickey, Just dyno test ,on my ss engine.
Old 12-18-2011, 10:15 PM   #16
Mickey Whaley
Q jets are funny get a good one it really will be a surprise the difference!
Old 12-18-2011, 10:37 PM   #17
Weekend Racer
Yes ,mine need some upgrade or tuning !
Thank,
Old 12-19-2011, 10:54 AM   #18
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Turbine is used to mearsure air flow (cfm) engine is using,usaully has cat (carb air temp) sensor mounted in it also.
My engine does'nt make near that power, pure stocker,my Q jet will match HP all way through and have about 3lbs. torque less @ peak than 750 holley. I compared on 351C on time w/ my q,jet 750&850 dbl. pumps and had same results.
I leave turbine off and mount cat sensor on carb to where it picks air temp going in carb so correction is repeatble.
Mike Taylor 3601
Old 12-20-2011, 03:09 PM   #19
Weekend Racer
Wink Re: Q-jet and Holley
This is very interesting subjet?
Thank a lot everybody!
Old 12-21-2011, 03:36 PM   #20
vic guilmino
Liked 56 Times in 21 Posts
i removed a 780 holley and
i put a q-jet on my 429 ford
same mph but et was .2 slower
carb when very rich in the first 100'
need help with that
Vic Guilmino 1129 STK
