Old 12-22-2011, 12:05 PM   #51
Crew Chief
Liked 10 Times in 6 Posts
Default Re: roller rockers
Originally Posted by Dirk Olson View Post
My understanding is that NHRA is building jigs to check ratios.
Dirk
No need for complicated stuff.
This will be one of the easier checks for tech to do in teardown. Just check the lift at the retainer, then at the lifter. Then divide the numbers.
Crew Chief is offline   Reply With Quote
Old 12-22-2011, 12:42 PM   #52
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
I would have rather had roller lifters to match my cam. Maybe next Christmas.
Pedigo Perf is offline   Reply With Quote
Old 12-22-2011, 12:53 PM   #53
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
When it comes to STOCK ELIMINATOR,the saying "Christmas comes sooner than you think" might just be the case!
Old 12-22-2011, 02:05 PM   #54
KRatcliff
Liked 534 Times in 143 Posts
Just remember, the change to roller lifters will modify the harmonics in your engine due to the knife edged crank which will alter your NOS settings.
A consideration.
KRatcliff is offline   Reply With Quote
Old 12-22-2011, 02:10 PM   #55
Pedigo Perf
Darnit Kyle, you know if I had NOS I would run it in Super Gas where the DP's and CJ's should be.
Old 12-22-2011, 02:13 PM   #56
KRatcliff
Super Gas? How would you slow them down that much?
Old 12-22-2011, 02:27 PM   #57
Pedigo Perf
With a keyboard and a mouse, how else!
Old 12-22-2011, 06:41 PM   #58
Bill Harris
Liked 26 Times in 13 Posts
Guess I'm a dumb-*** but why would the exact rocker ratio matter to NHRA tech? The lift at the valve would seem to be the important spec, so measure at the retainer and if it is in spec, it is good. The amount of machining needed to use a significantly different ratio rocker on a particular engine to maintain the geometry and have pushrod clearance is probably illegal anyway.
Anyone who has measured the OEM rockers know the last thing they have is an accurate ratio. Measure 16 of them and your probably going to get 16 different numbers.
It's sort of like the rod/piston/pin issue a while back. The total weight of the assembly is the guide so you can have a little lighter piston with a little heavier pin or rod, etc, as long as the total weight is good, it's OK.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
