Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 01-03-2012, 12:34 AM   #1
Axis Racing
Default Competetive 4-cylinders in Comp?
Who runs a competetive 4-cylinder Comp car, and what engine are they running?
Al Ackerman (engine ?)
Frank Aragona Jr. (engine ?)
Greco?
Axis Racing is offline   Reply With Quote
Old 01-04-2012, 09:21 PM   #2
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: Competitive 4-cylinders in Comp?
I'm a 4-cyl comp wannabe racer, so I go to the staging lanes when comp lines up when I'm not in my own race.
The Aragona cars have had a Mopar DOHC four recently, which I think is the same as a Mitsubishi. They also made a Subaru engine work very well.
Ackerman had a splayed-valve Chevy head on what I believe is a Pontiac Super Duty block
Charlie Greco's Opel that was driven by Dave Yediny had a combo similar to Ackerman's, but his Cobalt has a custom made block, also with a splayed-valve head.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 01-04-2012, 09:47 PM   #3
art leong
Tony. Frank Aragona uses a 4 cylinder push rod motor (similar to the LA motor). Nothing resembles the DOHC Mopar motors. I run a 150 cube DOHC Modified production motor in my Superstocker SS/GS.
I believe the DOHC motors can be competitive at around 135 cubes. If you can get a car light enough.
Art Leong 2095 SS
Old 01-05-2012, 06:18 PM   #4
Tony Curcio
Art, you may be right about their current combo. When the altered was first brought out,(maybe 2008 or 2009?), the engine had "MOPAR" on the big valve cover. I asked Frank Jr. what kind of engine it was as he strapping in, and he looked at me like I was stupid, and said "Mopar". I had clearly picked a bad time to be asking dumb questions.
Old 01-05-2012, 07:31 PM   #5
art leong
It is (was?) a Mopar 4 cylinder. Just not like the ones the power Neons or PT Cruisers.
Same number of cylinders after that there is nothing in common.
Art Leong 2095 SS
Old 01-07-2012, 07:20 PM   #6
Tony Curcio
Default Re: Competetive 4-cylinders in Comp?
I understand now. In fact, the engine I was thinking of has 4 valves, which wouldn't be legal in the altered class they run.
So what year & model would this pushrod engine be from?
Old 01-07-2012, 07:33 PM   #7
Dave Ley
Liked 241 Times in 44 Posts
Send a message via AIM to Dave Ley
Tony, It's basically half a Hemi. It was an engine that was used in the Indy Light series.
Dave Ley
Dave Ley is offline   Reply With Quote
Old 01-07-2012, 07:39 PM   #8
FED 387
Liked 333 Times in 180 Posts
Wink Re: Competetive 4-cylinders in Comp?
Aragona utilizes a Mopar A-4 cylinder block along with the new style Pro Stock Hemi head---if you are thinking about a 4 cylinder be fore-warned you will end up making/fabricating many of your parts and you have to either be a machinist have friend that will work for free or have access to a machine shop to do that---good luck "come in the waters fine"
Old 01-07-2012, 08:50 PM   #9
art leong
This is very true. I thought my engine would have a decent array of performance parts, because of the interest in the SRT4. Well I soon learned that if it doesn't have a turbo and a manual trans. You were on your own.
The first 2 years I ran my car I used an intake manifold from a dodge caravan. And cams that would check legal in a stocker. Camshafts were almost not available for a N/A engine (nobody had cores) My exhaust cam is a stock cam that has been welded to increase lift,
Things as simple as a 2 step were a challange. I had a trans brake made one of 2 in the world. My final drive (rear end gearing to you RWD guys) ratio is 3.94, and thats with custom made gears.
But little by little I'm getting it sorted out. I have had some help from the soft index. But with the amount of one-of's I need I deserve it.
Art Leong 2095 SS
Old 01-09-2012, 02:58 PM   #10
david ring
david ring's Avatar
You can run a four valve, four cylinder in H/EA-we have one in my car-Al Ackerman built it using a block and head out of the Colorado pick-up-it is a 2.9 liter motor (177 cubic inches) in stock form-we race it at 170 cubic inches. For H/EA, the motor must use carbs and the weight break is 8.25 lb.cubic inch. Fuel injection can be used in L/A or L/AA and the weight break is 10 lb/cubic inch (2 valve) or 10.5 lb/cubic inch (4 valve)..
Professor Dave
david ring is offline   Reply With Quote
