Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 01-10-2012, 02:12 PM   #1
mattclow
Default What would I need to weigh?
What would a dragster need to weigh with 146 cu. Inches
mattclow is offline   Reply With Quote
Old 01-10-2012, 02:16 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: What would I need to weigh?
depends on the class--remember its all about pounds per cubic inch WITH DRIVER INCLUDED----TOTAL WEIGHT
Old 01-10-2012, 02:28 PM   #3
mattclow
Naturally aspirated.
Old 01-10-2012, 02:39 PM   #4
FED 387
still no help--carb no carb ---transmission type ---4-6-8 cylinder engine--- etc---what class do you think ya wanta run
Old 01-10-2012, 04:43 PM   #5
art leong
Sounds to me like 2.4 liter could be carbed or F. I.
Art Leong 2095 SS
Old 01-10-2012, 05:19 PM   #6
david ring
david ring's Avatar
If carb, 2 valve pushrod, automatic-that is F/ED and needs to weigh 910 pounds with driver.
If four valve, can only run F/D, no matter what and needs to 1095 pounds with driver.
If 2 valve with purshrods and FI or EFI, you should run a clutchless five speed and needs to weigh 1020 with driver.
david ring is offline   Reply With Quote
Old 01-10-2012, 06:28 PM   #7
mattclow
Thanks for the replies, just doing some bench racing and wondered.
There is a naturally aspirated, overhead valve, pneumatic valve spring, 146 cu.in. V8. That makes 740 hp and 202 ft lbs at 18000 rpm motor out there.... guessing the pneumatic spring part might be tough to get by tech
Old 01-10-2012, 07:40 PM   #8
FED 387
not sure about that but I do not think anything other than a "conventional" automotive valve actuated system is legal--but I've been wrong before
