I see there are 5 options available for this motor.
Casting #s 3918903 3860384 3905393 3872783 3875954 Anybody know which is the best application for sbc |
Liked 53 Times in 17 Posts
What car? Year? Hp ?, are you doing?
68 Camaro 350/295hp, D,E or F/S
Liked 783 Times in 195 Posts
The best one will likely be the lightest one.
Liked 719 Times in 220 Posts
Hi. I did a little research,since I have a '68 Chevelle 327 car.
Intake#1 should be #3919803. That's the OEM intake for the 327 250,275,and 325 horse, as well as the 350/295. Intake # 2,#3860384, appears to be a service replacement part. Intake#3,#3905393,is an OEM '67 327 intake. Intake#4,#3872783 is anOEM '66 327 intake. Intake#5,#3875954 appears to be another service replacement intake. As far as which one is best, there probably aren't much different if at all.After they get matched to ypur motor, any one of them probably would work. The 393 and the 803 seem to be the easiest to find. Best wishes on your project!! . |
Thanks for the help.
The 783 intake is for a very small Holley that was offered on the 275 hp 327.
I think even smaller than the 585 cfm one on the L79. I didn't know that was on the 295 hp 350, but I don't think it would be the preferred option.
James Schaechter 3163 STK |
Liked 71 Times in 23 Posts
Dwight is correct.
I have ran both the 803 and the 393, there is no difference in the two. I would just leave it outside all winter then install LOL.
Monte Howard 3209 STK, 3208 SS |
Seems that in 66, the QJ and the Holley intake had the same number.A Carter AFB was also in use that year.
There is something amiss with that.Maybe the guide is incorrect. I have the Q jet and Holley manifolds. A Qjet won't fit on the Holley one. I think an AVS uses the Holley ( 783) one too.
