Old 01-20-2012, 10:33 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default front spring suggestions
Please tell me about your front spring choices. Is there an after market vendor/manufacture who custom builds accurate spring choices?
Specifically, factory style front springs as used on stock/super stock racers.
Also, is there a "home method" to measure rate of a factory type spring?
Larry Woodfin 471W
Old 01-20-2012, 11:26 PM   #2
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: front spring suggestions
I have Santhuff. Problem is you have to cut a complete coil off for the to fit into factory lower control arms as the are machined flat on both end of their springs. I am not comfortable with the flat side not sitting flush in the lower control arm spring pocket and do not want any cutting or abrasions that might lead to a cracked arm some day.
Chris.
chris ok is offline   Reply With Quote
Old 01-21-2012, 10:32 AM   #3
BlueOval Ralph
Banned
Call Eaton springs in Detroit
BlueOval Ralph is offline   Reply With Quote
