#51 |
Liked 184 Times in 113 Posts
Todays ProStockers are unrecognizable without the name being printed on the car.
Nice to see the latest development of the original concept. Top Stock tried to revitalize the original concept but have seen little of that in a while. Think the key issue that killed it was trying to balance the HP values of too many engines. IMHO Top Stock Eliminator cars should be a seperate class from Stock. Set the weight limit to 8.00#/cuin. Minimum weight of 3200lbs 650 CFM Carb limit, No Hood scoops, Stock Hoods. Any Cylinder Head, Iron Blocks, NA. Use Engine Master rules to build a 2500-6500rpm engines. Maximum Cam Lift .550 any Rocker 10 Inch tire, Stocker Suspensions. Have a Frontal Surface Varience factor for big faced cars. That way a slick Vette and Polara can compete. AND so racers can have something to gosip about. All other Stock Eliminator Rules in play.. |
#52 | |
Liked 20 Times in 3 Posts
#53 | |
#54 |
Mike Edwards #1 again.
Ed Wright 4156 SS/JA |
#55 |
Liked 6 Times in 5 Posts
#56 |
Liked 5 Times in 2 Posts
Yep! Mike Edwards has no idea what a soft tune up is. 0.982 sixty on the first pass and 168mph to the eighth. His car was moving on both ends. Looks like everyone else was a lil soft, undergeared, or too aggressive in the first round.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#57 |
Liked 58 Times in 18 Posts
Well look what happened when they all had to weight and fuel check, like i said on an earlier post this happens almost every year and then somebody has to say look how fast they are,
#58 | |
Last night the announcer said Alan Johnson has run extremely fast in pre-season testing before then appeared to struggle to match it when the season starts.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 02-12-2012 at 09:59 AM. |
#59 |
Liked 333 Times in 180 Posts
another thing when they test in Florida they are 50 feet above SEA LEVEL Pomona is like 1600 feet ABOVE(claremont airport is across the street from the track)---take some time off for that- coupla hun at least--while some people can run great times and test at 1600 feet not bogus times like those 50 footers
#60 |
Liked 2 Times in 1 Post
Yeah, but how about that Courtney Force!!!
