Liked 20 Times in 12 Posts
A friend of mine has a SBC stocker and recently experienced a problem. He made several passes with no problems. But on his last pass once he crossed the finish line and got out of it it started pooring smoke out. He saw it, cut it off and coasted off the track. When I got to him he showed me where the dip stick was pushed out and trans oil was everywhere!. It is a T200 with a breather tube on the firewall and a locking dipstick. He just loaded it up and went home. The trans seamed to work ok after that. What could cause this? The trans is not brand new but not wore out. Any ideas? Thanks
Liked 203 Times in 52 Posts
Does the breather tube go to a catch can?? All of my 200r4 do this when hot,so I built a nice catch can with a drain ****
Kevin |
Liked 280 Times in 139 Posts
I run a m200 in my stocker, heard of that happening. Seeing it never did it before I would pull the pan and have a look. You say it pushed out the locking dipstick, did you just install it. The orig. one has a v in the upper seal which helps in venting. gsa612
Liked 1,919 Times in 432 Posts
Does he know what his transmission fluid temperature is?
If it pushed a locking dip stick out of the tube, the vent system is stopped up somewhere. In any event, that much pressure is a sure sign of a fair amount of heat.
Alan Roehrich 212A G/S |
#5 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 536 Times in 110 Posts
X2 on what Alan said. High fluid temps, over full condition, plugged vent or an internal hydraulic oil pressure leak can cause this as well. It's best to fill race transmissions to the 1 pint below full mark if the dipstick is labeled as such. Hope this helps, just my .02.
Jim Kaekel 3836 STK |
Liked 56 Times in 27 Posts
I still agree with having an over -flow bottle for M-200 ... Also agree
with running it a pt. low to start ...Check the dipstick & tube for cracks. Agree with Alan on fluid temp ? Make sure you check level after a few passes , if its low for a while it will start to flash higher in the 1-2 & 2-3 shifts .... Good Luck ,
Dave Ribeiro 1033 STK |
Liked 22 Times in 7 Posts
If you used an aftermarket chrome dipstick tube with your original dipstick............the tube is 1 1/4 inches too long....your trans could be overfull by a little over 2 quarts.............
Liked 239 Times in 114 Posts
I always check the calibration of dipstick, If you have a production pan the full hot mark should be right at the pan gasket. Full hot is measured at 200 degF. transmission temperature. If you overfill the trans the oil will get up into the rotating parts and whip up like a milkshake. The venting system cannot handle that volume of frothed up oil and will spit it out. Also, sometimes the pump halves are not flat, and high pressure oil will cross leak inside the pump. This could cause oil out the vent. The pump halves need to be flat, and torqued to factory specs.
Liked 16 Times in 5 Posts
one possibility toois that after several passes the fluid got hot enough to boil and spew out. aithappened on a tow truck once (and had a little fire).
