Old 01-30-2012, 09:06 PM   #1
JeffM
Liked 5 Times in 5 Posts
Default Dana 60, alumastars, and misc parts
Pair of 041x heads - Cleaned, magged and pressure tested bare stock - $425.00
Pair of 461x heads – Cleaned, magged and pressure tested bare stock - $550.00
327 Forged Crankshaft std std – will need to be turned likely .010/.010 $150
15 x 12 pair - Chevy pattern with screw holes. 5"BS not perfect, but they run out nice and what I ran the past year. $450.00
Heads Up! Super Victor intake manifold - $350.00
NOS Rod bearings in original packaging- $20.00 per set of 8
CB663P – 2 sets of 8
CB663P-1 – 2 sets of 8
CB663P-20 – 1 set of 8
CB743P-1 – 2 sets of 8
CB743P-10 – 1 set of 8
CB745H – 1 set of 8
CB745P – 2 sets of 8
CB745P-10 – 1 set of 8
CB745P-30 – 1 set of 8
NOS Main Bearings in original packaging
MS429H – 2 sets - $50 per set
MS429P-20 – 2 sets - $50 per set
MS429P-20 coated – 1 set - $100
MS829P-30 – 1 set - $50
NOS piston rings in original packaging
R20109-5 - 4.125 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20109-65 - 4.180 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20100-65 - 4.060 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20101-5 - 4.000+5 in. Bore, 0.043 in., 0.043 in., 3/16 $125.00
E377X - 4.000 in. Bore, 5/64 in., 5/64 in., 3/16 in. $20.00
Energy suspension GM AT trans mount 1108G (black)- $15.00
MSD 8201 coil $50 – like new
Set of 8 LS1/LS6 injectors GM pn12561462 – Bosch pn0280155931 (28.8@58psi) - $250.00
New open box never used ARP early LS stud kit pn234-4316 – $300
New in sealed box ARP late LS Stud kit pn234-4317 - $250
New ATI crank pinning kit pn918993 - $75.00
New Comp Cams poly locks 7/16 - 1 set –$25.00
New Comp Cams rocker studs – 302 Ford 3/8 x 5/16 pn4504-16 –$40
Set of 8 take off L92/LS3 intake rocker arms pn12569167 less than 3000 miles in great condition $50.00
Dana 60 rear differential with Summers brothers spool, Richmond 5.86 Pro gear with lightened ring gear. Approximately 60 runs on the gearset. Moser 35 spline axles, gun drilled and star flanged with 5/8 studs (chevy bolt pattern) TA performance Aluminum rear girdle. Moser 1350 yoke, and driveshaft collar and bracket. Ladder bar brackets and wheelie bar brackets. 49” axle flange to axle flange. Comes with Strange caliper brackets. Wheelie bars also included. Come out of 66 Chevy II. $1700.00 OBO
Buyer pays all shipping costs or to pick up. Contact Jeff at superstock@live.com or 260-223-0157
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Search this Thread:
Advanced Search
