#11 |
Liked 172 Times in 46 Posts
Alan, is right you will never get a good pattern on a used set. You can shoot for the moon but be prepared to have a less than ideal pattern.
Dirk
Dirk Olson 5036 STK |
#12 |
Rusty, just set up a free account at photobucket, and post your pics here. I really can't see pics on my phone well enough to see a pattern.
Alan Roehrich 212A G/S |
#13 | |
Liked 460 Times in 91 Posts
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#14 |
Liked 101 Times in 27 Posts
#15 |
Run out on the spool , gear not seated flat against the spool . Backlash will vary as the teeth move closer . ---Trevor
#16 |
Rusty, what you'd need to do, is take the gear off of the spool, put the spool back in the housing under a little pre-load, and use your dial indicator to check for any "wobble" on the face of the spool where the ring gear mounts. You don't want to see more than about 0.002", and of course less is better. Sometimes at 0.004", it gets really difficult to set a gear up.
This is usually not a problem. If your backlash does not vary more than 0.002" when checked at 4 to 8 places, 90 or 45 degrees apart, then runout is not likely to be a problem. I find this to be a problem in maybe 1-2 out of 30-50 spools or carriers. If it is a problem, you can often rotate the gear on the spool either 90 or 45 degrees, and solve enough of it to be able to proceed.
#17 |
What need to do is check the spool in the case, caps torqued, no ring gear. Take a dial indicator and set it so that you are measuring the surface the ring gear mates to the surface the ring gear is bolted to, rotate the spool, any movement off .ooo is your runout.
Dirk
#18 |
Geeeeeeeessssssss.....you guys are the greatest....thanks for helping an old man. IF I WAS DOING THIS BY THE HOUR THE CUSTOMER WOULD HAVE TO GET A HOME EQUITY LOAN !!!!!!! HAHAHAHAHAHAH Actually it has been really interesting and I am so thankful for you guys helping me along with some others, plus I am not in a hurry. When my patience starts giving out I just cut the lights out for a few days and come back later. Thanks again all of you. Keep the info coming. This website is really a good thing.
#19 |
Rusty,
Glad to help. If you need to send pictures you can send them to my email address and I'll be glad to take a look. By the way, I might be interested if the 5.00 gear is for sale.
#20 | |
Liked 976 Times in 311 Posts
