Liked 13 Times in 7 Posts
Does anyone know what this suffix code is from a Chevy 350 T0627CNN ?
N/A |
Liked 333 Times in 180 Posts
Tonawanda
June 27,1970 350 ci/Turbo 350 trans TO627CNN |
also these engines came in A/F/X body vehicles
Thanks for the quick response.
Manny
N/A |
Liked 91 Times in 29 Posts
And if you really want to get technical it was a 200hp 2bbl
Here is another one. VO627 CKZ. Regarding the heads, which are better the 882s or 441s. I assume the 441s as they are slightly larger in volume.
block..........3970010 block casting date....F264 Heads....333882 heads casting date....N264 pad near alternator.......VO627 CKZ CKZ 1974 350 4 spd trans. J L48 195 4 Vette
N/A Last edited by mannymen; 02-02-2012 at 07:04 PM. |
Several answers come up for that code all are Corvette engines
V=Flint 06= June 27= 27th day of the month CKZ= 1972 LT-1, HD 4 speed 255HP 1973 L48, 4 speed 190HP 1974 L48 4speed 195 HP 1977 L48, 4 speed 180 HP you're gonna hafta check the block casting date/part number to say which year it is for sure--FED387 |
Liked 68 Times in 31 Posts
Hey FED what is this code. vo426xcd any idea?
Ron Mattson 5015 STK |
probably an over the counter replacement engine/block or a left over engine that was put into a "next year" vehicle say a 1969 into a 1970 --since the engine code for 1970 would not be correct on a 1969 engine they used a X to denote the change---most likely an LT-1 but you'll hafta check the heads/intake to be sure
FED thanks thats what i wanted to hear.
