Old 02-02-2012, 05:20 PM   #21
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Number of 81to 88 Olds stockers still running?
Chuck -
I knew that Karl bought the car from Sammy; I didn't know what happened to it after that. Thanks!
Didn't surprise me about Sammy. He's the only person I have ever seen lay a SBC crankshaft on the ground from a stocker. He did it at Baton Rouge also in the 327-250hp '68 Chevelle wagon that the Doughty brothers have. Set the record on that run, IIRC.
Old 02-03-2012, 12:13 AM   #22
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Curt Reese, Pierre, SD has one. Running 9 inch rear tire & stock suspension in GT/MA with a 283
Tracy Battest, Aberdeen, SD has one. Running P/SA I believe.
Glen DeMenge, in northern MN had one of the fastest M/SA but sold it. Where did it go?
Ed Drucker, CA, has one running J/SA
Bob Elliott, AZ ran one last year in K/SA
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 02-03-2012, 01:46 AM   #23
holben
Liked 2 Times in 1 Post
The car that Bill Prince had was originally mine. We never had any issues with the windowed blocks and we ran it pretty hard: shifted at 6500 and ran through the lights at 7000.
holben is offline   Reply With Quote
Old 02-03-2012, 02:44 AM   #24
Bernhard
Where you using a steel crank?
Bernhard is offline   Reply With Quote
Old 02-03-2012, 10:05 AM   #25
JRyan
Liked 112 Times in 31 Posts
Dean,
Joe Reid has Glen's old car.
Curt Rees' car was a fun street car. When we had it. It had an aluminum headed Olds 455. It would run high 11's in street trim.
Old 02-03-2012, 10:38 AM   #26
sammy pizzolato
Liked 56 Times in 13 Posts
Send a message via AIM to sammy pizzolato
dwight the car that i sold to karl was not the car i won the world championship with.we put the drive train out of the green car in that one.i still have part ownership in the origional car with and old friend i grew up with. it sits at his house still has the same paint on it.and the 307 blocks were JUNK!!! as you witnesed.the car i sold bo bo was a six cyl car i bought with a junk motor in it.
sammy pizzolato is offline   Reply With Quote
Old 02-03-2012, 02:30 PM   #27
holben
No, standard cast crank.
Old 02-03-2012, 02:45 PM   #28
JRyan
We're still using the same lightweight cast crank that we started running in 2000. It has well over a thousand runs in our Superstocker. It probably helps the crank a bunch to have it in a sleeved 350 or DX block as ours is. Keeping your fingers crossed must help too, as those cranks certainly don't look as though they'd take that kind of abuse.
Jerry
