Old 02-05-2012, 02:33 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Maximum Valve Spring Pressure
What is the safest / maximum spring pressure one can run in a SBC with press-in studs?
Thanks
Manny
N/A
mannymen is offline   Reply With Quote
Old 02-05-2012, 04:07 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Maximum Valve Spring Pressure
They tend to pull out or break with the stock springs.
Old 02-05-2012, 06:57 PM   #3
mannymen
"They tend to pull out or break with the stock springs"
Under what kind of conditions does this occur in?
above or under 6500?
over 300 lbs open pressure?
N/A
Old 02-05-2012, 07:31 PM   #4
tj310
Problems occur with stock rocker arms if they pinch the stud at full lift, shorter pushrods may help, we used to run stock Z28 springs.---Trevor
Old 02-05-2012, 08:52 PM   #5
mannymen
Paul,
Thanks for the info. My plans are to use a set of stock 441 heads 1.94 - 1.50 (press in stud) with z28 springs and aftermarket roller tip or full roller rockers. For some limited street time and some bracket racing.
The camshaft will be in the ballpark of
327 / 350 hp cam
or something similar below
Camshaft Lift: .450 Intake /.460 Exhaust
Flat Tappet Duration @ .050" (222°Int/222° Exh)
N/A
Old 02-05-2012, 09:07 PM   #6
Paul Precht
Some heads might be fine but there is an inconsistency from head to head and stud to stud. If the heads have a good history a slight step up from stock should be OK
Old 02-05-2012, 09:47 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
i've had the studs "pinned" before, might be an alternative for ya...
Old 02-05-2012, 11:13 PM   #8
rustbucket79
You're not going to break studs with that cam/spring combination, and you shouldn't be pulling studs either. If you want a guarantee, drill the stud bosses with a 1/8" bit and install hardened roll pins, or have a shop pull the studs and tap them for repair studs. (shoulderless studs)
rustbucket79 is offline   Reply With Quote
Old 02-09-2012, 01:42 AM   #9
trmnatr
All studs should be pinned or screw in studs and guide plates
trmnatr is offline   Reply With Quote
Old 02-09-2012, 11:53 AM   #10
Harry 6674
The cost is cheap compared to popping off a retainer. I found that out a long time ago.
Harry 6674 is offline   Reply With Quote
