#21 |
Liked 26 Times in 13 Posts
Not being a tech man, I neither know or care about the procedure to determine if the crank is legal or not. The fact that someone would go the expense and effort needed to convert a 305 crank to a 350 application, when 350 cranks are a dime a dozen, leads one to believe that there is an advantage to doing so. A similar advantage could be had by using a lightweight aftermarket crank for the 350, a huge variety of which are also a dime a dozen. In either case, their use is ILLEGAL and that is THE POINT. The rules are there, they are clear enough and anyone who ignores them or thinks they are just "bending" them to gain an advantage is a CHEAT. PERIOD.
Bill Harris ex 2172 STK ex 2272 S/S |
#22 |
Liked 880 Times in 311 Posts
Sorry Bill, but I think you are a little too anal about the rules. Yes, we can all read and like you can quote the rule book. Before bashing someone on being legal or illegal you need to know something about the components they are talking about. By your logic a rod that came in a 305 and was put in a 350 would be illegal when in fact they are the very same. The ONLY difference in a 350 and 305 crank is in the depth and location of the factory balancing holes. That is due to the slight (grams) weight difference in the 350 and 305 pistons. They both come out of the very same casting molds at the foundry. They are the same weight, casting number and dimensions. There is a BIG FAT "0" performance advantge. The only advantage is to the machinest that does the balancing with the approved NHRA component weights. Makes it easier Lighten up! No need insuating or calling a person a cheat!
Adger Smith (Former SS) Last edited by Adger Smith; 02-04-2012 at 03:22 PM. Reason: sp |
#23 |
Liked 308 Times in 103 Posts
To add to Adjer's post sbc 267-305-350 all have the same cranks the counterweights stroke all are the same like Adjer said only difference is 305 has deeper holes in countrweight then 267 has more holes,you can swap them without doing anything if you don't like your teeth or think you can hold a steering wheel that gets a 3'' thick when you rev engine,it would be like riding a bull can you hang on long enough or will it fly apart first.
Mike Taylor 3601 |
#24 | |
Adger You are correct in saying that all these cranks are basically the same although came in different engines and by the rule book would be illegal to use in any application other than their own. A good example is using a 427 Chevy truck crank put into a 396 Chevy BB but I reread Charles Rainey's thread and I think what he is asking is, if you add heavy metal to a crank that is not changing from external to internal--is it legal to do so and let it be seen or do you need to hide it by welding over it. I have always welded over mine just to stay pot of problems with NHra, but is it ok just to add one slug of say 1/2" heavy metal and go own or should we hide it cosmetically. I think that his is a good question that we can answer. reed |
#25 |
Adger is correct.
Ed Wright 4156 SS/JA |
#26 | |
Adgers analogy of the rods is BS. If I go to the parts counter for a 350 rod, or a 305 rod, they will give me the same part. NOT true of the crank. The statement "or should we hide it cosmetically" says it ALL. WHY would you have to HIDE it if if were LEGAL??????
Bill Harris ex 2172 STK ex 2272 S/S Last edited by Bill Harris; 02-05-2012 at 11:48 PM. |
#27 |
Just what I expected,
You didn't even answer my first question. All you spouted was your usual retoric. When I had to answer it you come back with more of your retoric to meet your own agenda. Bill, I've picked up and handled, (ground and balanced and resized) more 305 cranks and 350 cranks and 305 rods and 350 rods than you have ever seen. If 305 rods are different then why is it listed in the NHRA accepted products list on page 9 under Chevrolet that both 350 and 305 rods weigh 550 grams? Just an unfortunate coincidence, I guess. Just keep on telling people to F them selves and calling them cheats. Thats real big of you & helps push your agendas, too.
Adger Smith (Former SS) |
#28 |
Adger, you didn't read my post carefully. I agreed that the rods are the same.
" If I go to the parts counter for a 350 rod, or a 305 rod, they will give me the same part." I said the cranks were different... and they are. I have no agenda other than to participate in an organization where the rules are followed. I wouldn't think that is too much to ask, but obviously I am wrong about that. I'm done with this thread. Have a nice day. ![]()
#29 |
Liked 780 Times in 194 Posts
Bill - Take your meds.
Since the specs for piston-rod weights is a bit on the shy side from what reality weights are for factory pieces, sometimes it is easier to start with a 305 crank for a 350 application since it was balanced at the factory for lighter pistons. Less work that way, you know. |
