Old 02-09-2012, 09:41 AM   #31
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: Pure stock 340 Mopar
Originally Posted by James L Miller View Post
I think the current NHRA specs for a 1969 340 still apply to Pure Stock. The cam lift is higher on the exhaust. I think the service manual lists it as .429"/.444" or something like that, but Chrysler fed NHRA some enhanced numbers way back when.
HP Disp Deck Cl. Valve notch Int./Exh. Valve Cam lift
275 340 DP .045ab Flat w/n 5.45 cc 2020/1600 462/473 .035 Outer w Damp
I have 2 sheets of specs. The one dated Feb 1969 lists the lift at .467/.473 in one book.The duration is the same. The other sheet in my other book I have is dated the same Feb. 1969 but lists the lower lift . Go with the higher one. Chrysler did some funy things back in that era. Its good that you caught it.
Thanks.
Old 02-09-2012, 08:00 PM   #32
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Also have to keep back seat in pure stocker w/roll bar,I had to put mine back in which I like it better with it anyway
Mike Taylor 3601
Old 02-10-2012, 01:20 AM   #33
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Todd, I had the monte set up for g/ps. No x pipe or h pipe. It's my beleif that an x pipe would help if you have cheaper, non-equal length primarys. I never got the time to play with it on the monte. Spent too much time playing with the q-jet! Even though you're running a stock cam, a "healthy" converter will really help that low po (by comparison to a true stocker) engine get the car going wink wink.
Old 02-11-2012, 02:35 PM   #34
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Ihra Pure Stock
So, roll bars as a safety item is OK , would weld in frame connectors be allowed to tie it all together?
Steve
Steve Stickel is offline   Reply With Quote
Old 02-11-2012, 05:38 PM   #35
Todd Boyer
Liked 6 Times in 5 Posts
Originally Posted by Steve Stickel View Post
Ihra Pure Stock
Steve
I can't see frame connectors being a problem, I'm putting them in without a roll bar, but we should wait for Terry to chime in here on it.
Old 02-11-2012, 07:58 PM   #36
Todd Boyer
Terry, I see in the 2012 rule book that 9x30 tires are legal as well as "accepted aftermarket" ignitions. Would those include like a MSD 6AL for example ?
Old 02-12-2012, 12:29 PM   #37
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
9x30 tires? Does that include radial slicks? I showed up once at 42 with a set on my Camaro and was told to 'make sure that they were off the car the next race I went to".
Old 02-12-2012, 03:49 PM   #38
X-TECH MAN
Banned
Its been 10 years since I delt with any of this. I heard they increase the tire diameter to 9X30's. In the beginning many years ago only 9X28.5 was allowed so the fender well lips would not have to be "Massaged". Tied frame members were allowed early on. You might want to contact Mike Baker, Hank Blankenship, or maybe Danny Waters will jump in here. Electronic ignition conversions are allowed but the OEM distributor must be used. Again I would check with Mike Baker or one of the other guys still working.
Old 02-12-2012, 05:02 PM   #39
Todd Boyer
Cool, thanks Terry.
Old 02-14-2012, 03:19 PM   #40
65signet
Liked 49 Times in 22 Posts
John, did you run the Flowtechs in an A-body? I'm wondering how they fit?
The flowtechs do not fit good at all, they hit the T bars and other places, i ran then on A body for about a year took them off and intalled Hooker super comps, the fit and performance is very good.
65signet is offline   Reply With Quote
