Old 02-15-2012, 12:04 AM   #41
Todd Boyer
Liked 6 Times in 5 Posts
Default Re: Pure stock 340 Mopar
Originally Posted by 65signet View Post
The flowtechs do not fit good at all, they hit the T bars and other places, i ran then on A body for about a year took them off and intalled Hooker super comps, the fit and performance is very good.
Thanks for that. You get what you pay for I guess. I used to run Hooker Super Comp 1 5/8 but sold them, they fit very well. What year of A-body did you run the Flowtechs on ?
Old 02-15-2012, 12:43 PM   #42
mike coates
mike coates's Avatar
I have the 1 3/4" hooker supercomps on my dart swinger and they fit well. Better than the off brand 15/8 I used to run. I would think a 1 5/8 super comp would fit even better.
I really like to 2 piece design of the hooker. Makes it much easier to install.
Mie
Mike Coates
TBD
mike coates is offline   Reply With Quote
Old 02-15-2012, 03:21 PM   #43
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Pure stock 340 Mopar
The 1 5/8"-1 3/4" TTI step headers are the easiest headers I ever installed ina OEM chassis car.
Old 02-15-2012, 05:19 PM   #44
Todd Boyer
Are the TTIs a multi-piece design Myron ?
Old 02-15-2012, 05:27 PM   #45
Todd Boyer
Mie
It was a set of 1 5/8 Hooker super comps that I just sold, they fit great. Did you pick up or lose anything with the switch from 1 5/8" to 1 3/4" Mike ?
Old 02-15-2012, 05:42 PM   #46
Myron Piatek
Todd,
The passenger side is one piece while the driver's side has the #7 tube seperate to install over the frame rail. You also don't need a 90* oil filter adapter if using a short filter and they have good plug wire clearance. The driver's side was a little more difficult than the pass. side, but having the starter removed and engine pulled up off of the mounts is the way to do it. It's been a few years since I installed them with the engine in and it did involve a lot of engine wiggling and steering movement, but I believe I did it without removing the center link. But it was also on an open-center trailer with the engine jacked up. TTI instructions may call for link removal which would make it easier.
Some people have clearance issues, but that is usually the result of tweaked frames or worn engine or trans mounts that cause everything to settle. Just in case, a small bit of adjustment can be made in the mounts through shims on the '72 & older style or the engine can be shifted a bit with the later spool-type mounts. I like the poly mounts over rubber.
Plenty of oil pan clearance as well, even with the 8qt. Milodon that has the flared out sump. But obviously that wouldn't be an issue in Pure Stock.
www.ttiexhaust.com
Old 02-15-2012, 06:03 PM   #47
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Todd bring your car to Napierville for theis stock-super stock, IHRA and NHRA all run, great week end. CR
Old 02-15-2012, 06:08 PM   #48
Todd Boyer
I have friends who have been there, and I just may come up when the car is done !
Old 02-15-2012, 06:12 PM   #49
Myron Piatek
I don't base my decisions solely on magazine comparisons because there can still be too many variables. But maybe this Mopar Muscle dyno comparison can give you some more to think about.
http://www.moparmusclemagazine.com/t...ust/index.html
Old 02-15-2012, 06:25 PM   #50
cicero819
cicero819's Avatar
Myron, congratulation on your win this past week-end and great video. Claude
