Is it legal to smooth engine bay in stock. And do you need all factory body side mlds. These are glue on mlds. Thanks, Bob
Liked 33 Times in 17 Posts
Bob,
You have a PM. |
What is a mid?
Ed Wright 4156 SS/JA |
Liked 8 Times in 7 Posts
Liked 275 Times in 76 Posts
![]() FIREWALL Alterations prohibited unless expressly permitted in this section. Firewall coverings prohibited. Where heater/air conditioning units have been removed, area must be covered with minimum .024-inch steel or .032-inch aluminum, including rear hood seal/flange, as on GM A-body. Minor firewall modifications permitted to C5 and C6 Corvettes for transmission installation. See General Regulations 7:4. BODY Alterations or customizing prohibited; extent of customizing is limited to paint only. Convertible-top cars must run with top up. Sedan delivery, Ranchero, El Camino, etc. (if found properly classified in the Classification Guide) are eligible only if all class requirements are met. Raising and/or lowering front or rear of cars prohibited. Cars must retain level attitude at standstill, except those that have a forward rake (a permitted modification). Bottom of rocker panel cannot be higher than centerline of rear axle. Body mount insulators may be replaced with solid mounts of same size. Aluminum or other lightweight material may not be used to replace heavier items on car. In front-wheel-drive vehicles, air dams and spoilers that were available through the manufacturer are permitted front and rear. Unless someone see's something else? All body panels need to match year claimed. The glued on side molding should not be an issue, if its on or off. This info is out of the Stock section of the 2012 rule book Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 02-16-2012 at 12:18 PM. |
You are allowed to clean up the engine bay; fill old holes, cover heater box, paint, etc. What you are not allowed is to smooth the panels; for example the firewall can not have the seams cut down or otherwise blended. The reason for this is NHRA doesn't want it to appear you have build your own firewall and moved it back in the process.
Jeff Lee 7494 D/S '70 AMX |
I think I answered this before, but if I had a Fox body Mustang, I think I'd drill a few MORE holes in the fender wells...Who would notice?
Thanks for the info. Had to buy new aprons so i will get stock appering. Just not a fan of all the holes. Thanks again Bob
