Old 02-29-2012, 08:58 PM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: control arm bushings for 1st gen camaro
mannymen knows.
IIRC, there were no serrations on these polygraphite black bushings, Did this back in 2000.
Originally Posted by mannymen View Post
Ed did u just grind off your serrations from the bushing shells? To the other person responding, class racers still use this method that Ed has mentioned.
C.R. no reason to attack someone trying to help. Plus ask Dan fletcher what bushings he was using as u may be surprised.
Old 02-29-2012, 11:01 PM   #12
Chad Rhodes
I didn't attack anyone, I pointed out the inaccuracy of his statement, which was "you can accomplish the same thing". It's not the same thing.
Chad Rhodes 2113 I/SA
Old 02-29-2012, 11:19 PM   #13
1320racer
1320racer's Avatar
it is and it does and just because you don't think so, don't make it fact!
Old 03-01-2012, 10:47 AM   #14
Chad Rhodes
From an engineering standpoint it's not the same, period.
Old 03-01-2012, 10:59 AM   #15
1320racer
1320racer's Avatar
and you would know because you're an engineer right cause I am.
Old 03-01-2012, 11:23 AM   #16
Chad Rhodes
Really? You are? Then why am I giving you a lesson on deflection? An engineer should understand that. If you don't, and you are a mechanical engineer, then your employer is getting ripped off.
