Old 11-02-2006, 09:23 PM   #1
cd1892
Default sbc parts for sale
DaVinci Dominator carburetors, 1 pair, for gasoline, used on 2x4 sbc application - $2000
MGP #SB1400 aluminum connecting rods. 6.000 length, 2.000 rod journal, 0.927 wrist pin, new - $700
BME pistons for 12deg. SBC. 1 set of 10, forging #66mg F, 4.183 bore, 1.330 c.h., 2.750 x 0.927 pin, double spirolox, double upper oilers, keyway slots, 3mm oil ring groove, blob dome, top and 2nd ring grooves not machined, pin bores not honed, un-touched since purchased, new - $800
GM cast iron bowtie block #10051183. 8.890 deck height, 4.183 bore, 350 main, priority main oiling, 0.927 Jesel keyway lifter bushings located for 15deg gm heads, 55mm coated Jesel cam bearings, 4 bolt billet steel main caps, splayed caps 3 positions, race-ready, unused since honed and decked. - $3000
15 deg. Chevrolet heads. complete with 2.200./1.600 Manley ti. valves, 2.100 triple springs, l.w. Manley ti. retainers, 10 deg locks, lash caps, spring cups. zero runs since freshened. - $3500
MGP aluminum connecting rods. 5.850 length, 2.000 rod journal, 0.927 wrist pin, bronze bushings @ pin - used. $200
P.P.P.C. Casidiam coated steel wrist pins. 0.992 dia. x 2.750 lg. x 0.150 taper wall. 135 gram. 1 set of 8. new. $300.
Cola sbc crank, 3.200 stroke, 2.000 rod, 350 main, knife-edged, o.d.?d, rod pins drilled, used. $750.
Precision Crankshaft Grinding sbc crank, GM forging, 3.250 stroke, 2.000 rod, -0.010 350 main, knife-edged, o.d.?d, nitrided, polished, used. $500.
Crankshaft Specialties sbc crank, 3.100 stroke, 2.000 rod, 350 main, chromed, o.d.?d, rod pins drilled, used. $500.
Manley super 7 deg locks #13080. 5/16? steel, standard height, slightly used.
Manley 7 deg titanium retainers, triple spring, slightly used.
Del West 7 deg titanium locks, 5/16?, used.
Del West 7 deg light weight titanium retainer, triple spring, #565-LTW.
Callies crank snout stud #CPPI-013G, 6? lg, 7/16?NF - 7/16?NF. $10
MSD pro power coil, used. $50
MSD pro power coil #8220, used. $50
Peterson fuel regulator, used.
McClintic vacuum regulator. $25
Moroso inline scavenge oil filter - new. $35
Holley (Oberg style) oil filter - new.
Stef oil filter adapter #6740 - $35
Harwood #3157 dragster air scoop. $150
Spitzer Aero dragster air scoop. $200
Moroso BBC valve cover gaskets #93040 - new. $30
Comp valve springs #911-16. BBC, 1.525 o.d. w/damper, 125#@1.900, 300#@1.400, 1.200 coil bind, used approximately 100 miles in dually 454 engine. $45
Comp BBC exhaust spring spacers #4779. 0.300 thk, set of 16. $40
Comp 3/8? dia. Lash caps #622-16 - new. $30
Comp 5/16? steel super locks #610-16 - new.
Mallory Promaster coil #. $50
2 Holley fuel pressure regulators. $25
Strange 5/8? x 3? long steel screw in wheel stud kit, new. $50
1 gearset for Liberty 5 speed trans. 2.74-1.99-1.54-1.24-1.00 ratio - used.
9? Ford Pro-Gear, 5.14:1 ratio, used. $150
9? Ford Pro-Gear, 5.00:1 ratio, lightened, used. $125
9? Ford Pro-Gear, 5.00:1 ratio, lightened, used 1 run. $225
also have other miscellaneous sbc and dragster parts for sale. photos available upon request.
Chris Bozic
Comp1892@msn.com
412.767.5562
412.427.6183
cd1892 is offline   Reply With Quote
Search this Thread:
Advanced Search
