Old 03-13-2012, 02:07 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Thumbs down quench dome piston
want to what the term quench dome piston actually is? thanks jason
jaf2021 is offline   Reply With Quote
Old 03-13-2012, 03:51 PM   #2
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: quench dome piston
Quench, or squish area is typically the flat area on the top of the piston that's almost level with the top of the block deck. It must have a corresponding flat area on the deck surface of the head to qualify as quench.
If you look at a combustion chamber, you will usually see these flat areas, and they will have the volume of the actual combustion chamber between them. When the piston is compressing the mixture, as the piston nears the head, the flat areas on the head and piston come together and force the mixture from those areas to "squish" into the chamber, where the spark plug and burning mixture reside, so you achieve a more complete burn.
The quench area also runs cooler than the rest of the chamber / piston. These lower temperatures are where the "quench" comes from.
When properly designed, the quench areas can have a tremendous effect on the quality of combustion, and allow higher compression ratios, and due to this they are considered "artificial octane" by scientific types.Maybe, I could be wrong.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 03-13-2012, 05:47 PM   #3
jaf2021
thanks for the info jason
