Old 03-15-2012, 08:37 PM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Pure Stock Fuel
From what I've read, pure stock can run race or pump gas. Has anyone recently gone thru fuel check with pump gas ?
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 03-15-2012, 09:17 PM   #2
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
Default Re: Pure Stock Fuel
Pump gas will not pass tech, too many additives
Old 03-15-2012, 10:02 PM   #3
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Pure Stock is an IHRA class and they do not have fuel check at the Pro-Am races,so unless you are planning on going to a National event,you probably could even run VP113 and nobody would even know.
Old 03-16-2012, 03:07 AM   #4
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Pump gas at division races as they don't have fuel check. I had good luck running VP C10 (unleaded) back when we ran pure stock. Although it wasn't cheap.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 03-16-2012, 08:15 AM   #5
GallopinGhost
I plan on running a divisional, and will stick with pump gas if they're not checking. thanks
Brian Carpenter
Stock 1358
Old 03-16-2012, 08:32 AM   #6
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Pump gas is legal for Pure Stock ONLY due to emission controls on some newer cars.
Old 03-16-2012, 08:49 AM   #7
X-TECH MAN
Banned
If you are in Pure stock they do NOT fuel check you due to the newer cars emission controls. They may take a sample but they would not DQ you. They are just looking.
Old 03-16-2012, 09:30 AM   #8
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Pure Stock Fuel
white amaco was always recomended back in my day. You still had to stop and get checked unless waived by........If you did not stop you could get dq'd as you would not be on the fuel check sheet . You had to at least be in line and explain to official.....Don't know about current status.
Old 03-16-2012, 09:33 AM   #9
Mike Croley
Pump gas is really impossible to check or police . And that's because pump gas can be one of hundreds of combinations . There are numerous manufacturers of gasoline with their own combination of additives, and many thousands of gas stations in North America . A very few branded stations purchase and sell only their brand of gasoline . Most are free to purchase any gasoline on the market , depending on which brand is cheaper at the terminal on a given day . So the gasoline you buy at the pump , in most cases could be any brand and probably won't be the same brand that it was last week . And the standards for pump gasoline are fairly relaxed compared to the standards for race gas . The ethanol content in pump gas can vary 2 or 3 percent from brand to brand , day to day . And there are pump gasolines that have no ethanol at all . And to add to the thousands of possible combinations of gasoline , there are 2 or 3 choices of octane at every pump , all of which have a different chemical make-up .
So setting benchmarks for testing pump gasoline would be impossible unless you allowed a pretty wide variance or the sanctioning body restricted pump gas to only one or two brands . And even that would be very difficult to police due to seasonal and regional variations .
Mike Croley is offline   Reply With Quote
Old 03-16-2012, 10:36 AM   #10
GallopinGhost
It's understandable how difficult it can be to test pump gas. I just hope that when I'm in line for fuel check, I get waved thru, and the person checking fuel is on the same page. Thanks for the info.
Brian Carpenter
Stock 1358
