Old 03-18-2012, 04:06 PM   #1
Stick Racing
Default Clutch disc
I have rung the spines out of a clutch hub this week. After careful inspection, I have discovered that the disc I bought form Bonninfante has splines that are approx .300 long in the hub. I picked up a disc from Ram and measured the splines in their hub to be approx .420 long. I would like to just replace the hub on the disc without buying a new disc. The flywheel and PP show very little wear. Would like to swap hub for the thicker Ram piece.
Anyone try to mix hubs on discs?
Andy Stone
___________________________________________
1102 A/S 1112 SS/C
Stick Racing is offline   Reply With Quote
Old 03-18-2012, 04:11 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Clutch disc
If it fits, wear it.
Old 03-18-2012, 04:17 PM   #3
Steve Hayward
Call Tim Hyatt.......... 440 254 1311
Also........ http://www.umtrnorth.com/forums/default.asp
Steve Hayward is offline   Reply With Quote
Old 03-18-2012, 10:20 PM   #4
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I did the same 10 years ago, sent both pieces to Ram, they switched hubs , not a big deal, thinking it was fairly inexpensive. but Tim Hyatt may be quicker and cheaper.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 03-19-2012, 07:06 AM   #5
Greg Barsamian
Liked 427 Times in 97 Posts
Originally Posted by steve hayward View Post
call tim hyatt.......... 440 254 1311
also........ http://www.umtrnorth.com/forums/default.asp
x-2
Old 03-19-2012, 04:32 PM   #6
Stick Racing
Appreciate the info. Thanks.
Andy Stone
1102 A/S 1112 SS/C
Old 03-21-2012, 09:36 PM   #7
rod
Liked 20 Times in 15 Posts
i had McLeod change out a center not long ago. theirs was just bolted together. grade * bolts and stop nuts.
rod in AZ
rod is offline   Reply With Quote
