#11 |
Warranty doesn't do much to make a customer happy when they call because the car they paid you to fix stops running. I know too many other shop owners with the same experiences and opinions about fuel pumps as I. At least four a month (very busy shop) will give a lot more examples than ownning a couple of vehicles. Hold an original Ford in-tank pump (used to be Bosch) in one hand, and the Walbro replacement in the other. You will see what I mean. The original Ford pump will weigh about twice the Walbro. Plastic is lighter than metal. Don't know who makes Racetronic. Hope it's not Walbro. LOL
Ed Wright 4156 SS/JA |
#12 | |
#13 |
Peter, it was a problem up until I stopped doing that kind of work around 2005 or so. Didn't hear anything about Shell. Not many Shell stations here. Sinclair and Sun refineries within 2 miles of my shop. Pretty much all gas sold here locally came out of one of those two refineries.
#14 |
Liked 129 Times in 59 Posts
Capt'n Jack -
I seem to remember you having fuel delivery problems with this Suburban before, just not sure how you tried to fix it! Not sure why you'd want to run an in-tank pump with your 454 that's been converted to a Q-jet. You can get a 40 gallon replacement tank and fuel sender/pickup for an 1986 Suburban, which was the last year that the factory used a carb on the light duty trucks. If your block was fitted with a fuel-pump mounting flange, an AC Delco or Holley H/D mechanical pump should work just fine. All the big-block trucks had the 3/8 inch fuel line running down the passenger-side inner frame rail. I've never converted an '87 or newer Suburban to a carb from the TBI, but I've owned a few of each and tried to stay away from most of the non-OEM replacement fuel system parts. The cheaper pumps usually don't give you too much notice when they fail!
Lew Silverman #2070 "The Wagon Master" N/SA |
#15 |
Liked 511 Times in 122 Posts
thanks lew... you actually read my question.
without going back to the october 6 page thread i have tried most every imaginable fix for this... at no apparent issue the truck will go from 8lbs to 2lbs and presents itself like vapor lock. i have rerouted all lines including a new line into tank, had tank off 3 times, 3 mechanical pumps including current holley hi volume with an inline carter booster pump. this issue has been going on for 5 years and ive reached a tipping point... its fixed or sold. my conclusion was to make a fuel cell out of tank by adding an outlet in bottom of tank and plumb it like a race car with pump & regulator... i was wondering what aftermarket fuel pump was suggested, of course need one that will see 10-15 hours of continous duty on long tows... flow not as important as durability. also wondered about yes no to go thru mechanical pump. anyway i almost wished i left tank pump in and just stuck a regulator on it captain jack
Jack McCarthy 3609 STK "the Captain" |
#16 |
I can only imagine how frustrating this has been! I had an '87 Suburban with a 350 and TBI which used to do the same thing. Every so often it would stumble and set the CEL, until I shut the ignition off and then it would be OK until the next time! When I was dropping the tank for the 3rd time, I noticed that the fuel pump holder/pick-up and been modified by some previous owner to use an assembly from a pick-up truck, which at the time must have been easier than spending the $200+ the correct one cost me. After that I had no more problems, at least FUEL problems anyway!
One other "weird" thought - does this fuel pressure/vapor lock happen more frequently in hot weather? I remember reading that some of the folks who used the Suburban to tow the Airstream trailers complained about that same problem. Their solution was to paint the bottom of the fuel tank white to keep road heat away from the fuel! It worked for them!! Wish I could be more help! My only Suburban problem is the terrible gas mileage @ $3.50 a gallon means I don't go out a lot! ![]() Lew
#17 |
Liked 55 Times in 28 Posts
Remembering the "rules"
1. all electrical and/or mechanical stuff fails eventually 2. failure occurs at the worst possible moment So, I would place an electric pump like the Holley Red (etc.--whatever brand you like) down low in the back, and carry a spare already set up for quick replacement. In-tank pumps have been pretty reliable, but the reputation was made in years past when their quality was more certain. I would delete the mechanical pump; it is just in the way. Fabricate a steel line so there is a minimum length of rubber hose down low in the engine compartment. I had vapor lock problems a long time ago that was caused by proximity of the line to the exhaust system. I re-routed the line from rear to front to cure the problem. |
#18 |
Liked 19 Times in 7 Posts
There is nothing worse than a problem that cant be figured out. Im frustrated just reading this thread...but I dont think hanging a holley red under the truck is the answer and I wouldnt trust those pumps on a tow vehicle. Obviously if its loosing pressure there is something that is causing it. Is it possible that the gas cap isnt vented and or the vent is plugged? Try removing the gas cap and see if the pressure still drops. I had this problem on my station wagon and it was the gas cap not allowing any air by. It was actually sucking the tank and the lines inside out. I could do a burnout.....stop and lanch it. By the time I got into second it would loose all fuel pressure and run out of gas. Let it sit for 5 minutes and it would fire right back up and run perfect. Just a thought. Any rubber line in the fuel system that is old should be changed as well that way there is no chance that the pump can colapse it.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 02-07-2012 at 06:53 PM. |
#19 |
let you guys know next week... longtime racer who had a suburban just gave me a tip and it sounds like a winner...
thanks captain jack p.s. bob mulry... happens with cap in glove box ![]()
#20 |
well here are results...
the tip i thought was winner wasnt, gasline sucking shut at frame at pump was the tip. i replaced ALL fuel lines including in tank with new line, and new triple reinforced hose with no gap larger than 1/2 inch between lines. i installed a big end red (holley) fuel pump in rear by axle. i headed to belle rose... i DID need the elcectric pump at most times, but went there and home under power. not sure why i need all the overkill pump setup, but it works. thanks to those who chimed in jack
