Old 05-10-2007, 09:57 AM   #11
Dave Ribeiro
Liked 56 Times in 27 Posts
Default
Tranny fluid temp is important to life of parts and trans..So if you don't have a trans cooler you should change tranny fluid more often.
But, first of all you should add a drain plug if you don't already have one..This will allow you to drain out 2-3 quarts at a time and slowly replace the used fluid evey 25-30 runs...
I will not coment on dropping the pan to change fluid..I really think you guys are on a FISHING Trip !!!!! Trust me the Fletcher's
Biondo's, Morehead's, etc. , don't drop or drain their tranny pans between rounds or qualifiing....They just drive their butts off....But, I do think keeping fresh fluid in your tranny has its advantages................Dave...1033/stock (RV-455)
Dave Ribeiro 1033 STK
Old 05-10-2007, 01:09 PM   #12
slowstocker
Default
All about recation times.
slowstocker is offline   Reply With Quote
Old 05-10-2007, 03:00 PM   #13
Steve Keetch
Default
Are Delays legal in transmissions now?
Steve Keetch is offline   Reply With Quote
Old 05-11-2007, 08:14 PM   #14
Steve Keetch
Default
a friend of mine wants a trans with a delay or slow transmission for his super stocker here in Georgia. who makes them?
money is not a issue as he wants to make sure his trans has a delay in it to compete with the others who are running the transmissions
Old 05-12-2007, 12:02 PM   #15
Michael Iacono
Liked 6 Times in 6 Posts
Default
IF MONEY IS NOT AN ISSUE I HAVE A TRANS FOR HIM. ROSSLER POWERGLIDE DEDENBEAR CASE 1.98 FIRST GEAR 40 RUNS READY TO GO CALL MICHAEL 631-433-5906
Michael Iacono is offline   Reply With Quote
Old 05-12-2007, 12:26 PM   #16
Jeff Lee
Guest
Posts: n/a
Default
SS cars have evolved with better chassis, better slicks (radials) and better engines (lite-weight parts and more power) which allow them to leave much harder. Those areas of improvements make them faster but the item that out did the fast race parts was the LED light. Now you have cars capable of red-lighting on a consistant basis and therefore racer's find it neccessary to slow the car off the line while not slowing the race car down (with bias tires for example).
Having a method of slowing down a launch speed by making adjustments in the valve body or trans-brake solonoid should not be a problem with NHRA. After all, one function of an automatic transmission is to control fluid pressure. If anybody hasn't figured it out, some racer's have figured out how to control t-brake release times. It's just a matter of controlling fluid pressure. Good for them, I see nothing wrong with it. NHRA doesn't tell me what ring gap I need in my engine or bearing clearance, right? Just as long as the racer has to go back to the pits to make the adjustments. If radio-controlled devices are being used with the capability of making adjustments at any time, then that's bad news. And I can see how that technology is feasible (my dad has flown R/C airplanes since the mid '60's, amazing what can be controled in a confined space!).
Using this technology, it kind of makes long travel or hydraulic type t-brake buttons a non-issue to some, doesn't it? I would guess if I had ways of controlling the dump time of my t-brake, any .99 cent button (re; "spec" button) would be adequate.
My guess is I wouldn't want to be the one without the knowledge of controlling the dump speed of my t-brake and having an NHRA mandated "spec" button. Because while I was out red-lighting (often), some of my opponents would enjoy another .000 light.
Make sense?
I guess if NHRA were truly concerned about all these methods of controlling reaction times, they would eliminate t-brakes in SS along with RPM limiters. That's the only way to clean up the mess (if you believe it's even a mess). But I don't see that happening.
NHRA #7494 SS/H
1970 AMC AMX
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
JeffLeeAzRealty@Qwest.net
602-418-9797
Old 05-12-2007, 01:52 PM   #17
bsa633
Banned
Default
If it's an internal function of the transmission..i guess it's legal! the rules dont say anything else...
bsa633 is offline   Reply With Quote
Old 05-12-2007, 04:17 PM   #18
Lambertcars
Default
WOULD IT NOT BE A LOT EASIER JUST TO PURCHACE A BIONDO ADJUSTABLE BUTTON AND INSTALL IN THE CAR? THAT IS WHAT I DID IN MY SS CAR. SOME OF YOU GUYS WOULD SURE SAVE A LOT OF TRANS FLUID.
Allen Lambert
Lambertcars is offline   Reply With Quote
