Old 03-24-2012, 06:34 PM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Tri Y vs. Conventional Header....
my initial gains were with the standard F.O. years later I swap to the "C": F.O.
Can't say it was any quicker and it wasn't slower but definitely had a new sound.
Old 03-26-2012, 02:51 PM   #12
ron mattson
Liked 69 Times in 32 Posts
Wade check p.m.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 03-29-2012, 10:04 PM   #13
Grant Eldridge
Grant Eldridge's Avatar
Not really a thorough evaluation, but we did a dyno pull using the same stepped primary pipes, first pulls were with a 4 into one burns merge collector and 18" of collector pipe, then replaced that with a 4 into two into one merge collector setup with a megaphone style end. We changed nothing else and saw a 4 hp increase. We were chasing other issues and did not change the tuneup, but felt that at least we did no harm with the Tri-Y setup so intend to use them in the car and test further at the track. It seems that the fuel curve was considerably leaner than previous tests we had done but the BSFC numbers looked good on our dyno sheets so we'll give them a try...
Grant Eldridge is offline   Reply With Quote
Old 03-29-2012, 10:28 PM   #14
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: Tri Y vs. Conventional Header....
Originally Posted by Alan Roehrich View Post
I also have a side line. I stand in as a scarecrow for farmers. It's boring, but it pays, and nothing will go into one of those fields if it has any sort of decent eyesight.
Especially if you're wearing shorts!! Jim
Old 03-29-2012, 11:19 PM   #15
Liked 1,928 Times in 434 Posts
What really worries me is that you were actually looking ...............................
Old 03-30-2012, 12:15 AM   #16
NewHemi
NewHemi's Avatar
Now that is funny, I don't care who you are.....
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 03-30-2012, 12:53 PM   #17
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Grant, thanks for the info. I really think the 283 would benefit from them, maybe more than a larger cid. Its all theory for now, but, would I like to mock up a set and see.......
Old 04-02-2012, 03:37 PM   #18
Greg Hill
Liked 279 Times in 68 Posts
A Dyno is not the best place to try headers. A bigger header may make more power on the Dyno but be slower down the race track.
Greg Hill 4171 STK
Old 04-02-2012, 04:28 PM   #19
What you'd look for when dyno testing headers would be average torque and horsepower through the RPM range you're running. You'd also want to look at the acceleration rate you test at. You have at least 3 different acceleration rates, if you have a 3 speed transmission, and that does not account for the fact that once you shift from first to second, from there on, your acceleration rate (in RPM per minute) slows at a progressive rate, the higher the gear, the slower the acceleration rate.
Old 04-02-2012, 05:50 PM   #20
chassis1
Liked 9 Times in 3 Posts
a dyno is the only repeatable situation.......I know there are many who would rather make a million runs on the car and put more variables to see if a header is any better than another.....
dyno is much more affordable in my book......
chassis1 is offline   Reply With Quote
