Old 04-03-2012, 07:34 AM   #11
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Rear end gear oil
I have liked the Amsoil too, for a few years. Good stuff !
2894 STK
Old 04-03-2012, 09:49 AM   #12
Stock4106
Liked 10 Times in 4 Posts
Has anyone seen an on track performance difference between gear oils? I've changed brands and amount of oil a few times and seen no change.
Owen S. Birkett
Stock/Super Stock 4106
Stock4106 is offline   Reply With Quote
Old 04-03-2012, 10:21 AM   #13
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Rear end gear oil
There are several good rear end oils out there and I'm thinking it's more about how well the oil protects and extends gear life etc. rather than performance value. They probably all are pretty equal there. Just an opinion. BTW I have used the Amsoil for years now also. Jim
Old 04-03-2012, 10:49 AM   #14
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
based on the replies here, it should be clear that everyone has an opinion as to who's good or the best, no different than most everything about these cars and 99% of the time it's what they use.
Bottomline is they're all good and there is no difference other than price and choosing between conventional and synthetic. Also, if there's any performace to be had, it's going to come from quanity and viscosity. I know guys that have run synthetic engine oil in their rear ends too.
Old 04-04-2012, 10:15 PM   #15
rod
Liked 20 Times in 15 Posts
if you happen to be using a posi, rather than an open or a spool, do NOT use the synthetic lube, of any brand. even if you use the posi additive.
rod in AZ
rod is offline   Reply With Quote
