Old 04-09-2012, 05:05 PM   #1
bert powell
Liked 34 Times in 12 Posts
Default Super Stock engine rules
Guys, looking to build a spare motor and was wondering about the bobweight requirements. I know there are bobweights listed for stockers, what about super stock? Is anything allowed? Everyone is going to undersize rod journals so can the rods be any weight? Can't see much improvement in the smaller journal unless the rod is lighter. The hemis are not running Honda journals and 900 gram rods, can the other classes follow suit? Thanks for any input!
bert powell is offline   Reply With Quote
Old 04-09-2012, 10:21 PM   #2
bert powell
Default Re: Super Stock engine rules
220 views and no reply, must be top secret!
Old 04-09-2012, 11:05 PM   #3
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
No Secrets Piston and Rod weight are not restricted as for the Rod Journal Size thats one of those things if you have to ask you should stay with the stock size no disrespect just my two cents
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 04-09-2012, 11:05 PM   #4
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
The hemi rod must weigh the correct weight, but the pistons and pins are very light.
Dyno is online now   Reply With Quote
Old 04-10-2012, 12:54 AM   #5
Jeff Lee
Jeff Lee's Avatar
Super Stock can run any rod or main journal. They can run bearing reducers or accepted rods with the reduced size already taken into account. There are accepted rods with Honda size big ends. You can also run whatever size wrist pin you want. Or any deck height...
So yes, any bob weight you want is allowed in SS (using accepted parts; i.e., no aluminum or titanium rods).
Jeff Lee 7494 D/S '70 AMX
Old 04-10-2012, 01:27 AM   #6
rustbucket79
To ask the OP a question in return, what does your current engine have, and are you looking for a lower cost backup engine, or are you looking to build a "state of the art" engine and turn your current engine into the backup engine?
rustbucket79 is offline   Reply With Quote
Old 04-10-2012, 02:11 AM   #7
Liked 1,929 Times in 434 Posts
I suggest you look at the approved rod list, and contact your division tech rep or Glendora. There is no substitute for getting the answer in writing from Glendora. But yes, smaller journals are now legal, so are smaller wrist pins. There are big blocks of most manufacturers out there with Honda rod journals and 0.8xx" wrist pins. Any forged or cast crank is legal, billet cranks are not. Yet.
Old 04-10-2012, 05:37 AM   #8
GTX JOHN
Any Deck Height??
GTX JOHN is online now   Reply With Quote
Old 04-10-2012, 08:55 AM   #9
bert powell
I would like to make my current engine a backup, it was originally built in the late 90s. It has top dollar components but they are heavy, 820 gram rods and 570 gram pistons that were lightened. I think I can get at least 150 grams off the rod, piston and pin without hurting reliability. Don't think it will be worth any measureable power but should rev faster.
Old 04-10-2012, 05:02 PM   #10
Jeff Lee
Jeff Lee's Avatar
Originally Posted by GTX JOHN View Post
Any Deck Height??
Yes...in SS. That's why it is now legal to place your RB parts in a B block.
Obviously an issue in Stock though.
