Old 05-08-2012, 02:03 AM   #1
Rory McNeil
Default SB Ford CSR water pump O rings
I have a used CSR electric water pump for a SB Ford. It has an aluminum plate that attatches to the stock timing cover, and the pump itself bolts to the plate. I noticed that there are grooves for O Rings in the water pump body where the pump bolts to the plate, and I am missing one of these O Rings. The O rings are not round, rather they have an irregular shape. Does anybody know if these O rings are available anywhere? Or, if I could just use a bead of good quality RTV, like "Right Stuff" instead? I currently am using the stock Ford water pump with a Moroso electric belt drive, which is wired to run "backwards", since the factory 85 Mustang 5.0 serpentine belt setup runs counter-clockwise. I should be able to run the CSR pump wired to a "normal" though, shouldn`t I?
NHRA 6390 STK
M/S 85 Mustang
Old 05-08-2012, 10:19 AM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: SB Ford CSR water pump O rings
You can order the o-rings from CSR. Summit or Jegs might have them in stock.
http://www.csr-performance.com/shop/...lacement-parts
I would think that you would run the electric pump in the usual direction, draw from the lower radiator hose and pump into the block.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 05-08-2012, 01:04 PM   #3
Rory McNeil
Thanks Bill, I did see the CSR site showing water pump O rings, but those are not the pieces I need. Those appear to be for the pump itself, I need the irregular shaped O rings that go between the pump and the plate.
NHRA 6390 STK
M/S 85 Mustang
Old 05-08-2012, 02:37 PM   #4
David Lee
Liked 346 Times in 126 Posts
I think you can use normal gaskets if the O rings are not there
Old 05-08-2012, 03:21 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Rory,
Take your housing that has the grove in it, you should be able to match up the diameter and O-ring size at a hardware store. You will probably have to glue the O-ring in the groove to keep from cutting it, when you install it. The original water pump was a reverse rotation due to the serpentine belt rotating the pump backwards, compared to a conventional V-belt drive system.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-08-2012, 04:52 PM   #6
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
If you use permatex Ultra Gray to seal it, you won't have any problems. Haven't used O rings with my pumps in years
Chuck
C and W Racing is offline   Reply With Quote
Old 05-08-2012, 08:31 PM   #7
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Rory..."H"... If you get the pump to me, I can get you the o-rings from a supplier in Richmond. We use them for all our industrial sealing solutions. Maurice ("TFC").
MAURICE BLENDHEIM is offline   Reply With Quote
