Old 05-11-2012, 09:23 AM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,954 Times in 590 Posts
Default Re: afco spring sliders
They are not worth the work. I had similar ones on my car when I used leaf springs. I did not like them and put the shackles back on.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-11-2012, 06:27 PM   #12
Jeff Lee
Jeff Lee's Avatar
Mike,
What do you perceive as the problem? I'm considering them on my car.
Jeff Lee 7494 D/S '70 AMX
Old 05-12-2012, 11:13 AM   #13
Mike Pearson
Jeff
The side brackets with the slots that the springs were supposed to slide in were made from thin mild steel. The bolt through the spring was a 1/2 inch bolt with a thin wall mild steel sleeve that was supposed to roll on the bolt. The sleeve wore a groove in the slot and the slot wore a groove in the sleeve. So it actually was in a bind. I think the ones I had were either moroso or SRD. I guess if you made your own with a thicker bracket with the slot and made the slot wider where you could use an actual roller bearing it would be a good system. Maybe make the side bracket from some 1/2 inch aluminum plate with the slot milled in to match the diameter of a roller bearing. Then you would have something.
Old 05-12-2012, 11:55 AM   #14
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
We stock and sell a lot of them.
Many go out with Cal-Trac system orders.
I love the way they work and even have them on my own car. Same AFCO's since 1998. See pics.
They do need to be lubricated 3-4 times a year.
We also stock some really cool billet aluminum shackles for racers who do not want to go through the extra work.
Name:	Roller shackle 001.jpg
ID:	11570   Click image for larger version
Name:	Roller shackle 002.jpg
ID:	11571   Click image for larger version
Name:	Roller shackle 003.jpg
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
