Old 05-27-2012, 05:57 PM   #11
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Brake pressure switch
I ordered four when I bought mine. Even if you had to buy 10 you could probably sell the extrs here,lol
2009 V/SA Record Holder
Old 05-27-2012, 11:39 PM   #12
west coast
Liked 227 Times in 74 Posts
Robert pm me I have had the same problem with min of 10 to order. I need a couple of switches also.
west coast is offline   Reply With Quote
Old 05-28-2012, 02:32 AM   #13
GTX JOHN
I could use a couple or three myself.
Old 05-28-2012, 10:27 AM   #14
Steve Hayward
A good parts guy can find one..... they are preety comment..... I think they are used a lot in tow motors......... I pay about $10 CDN to prob 15 now for one.......
Steve Hayward is offline   Reply With Quote
Old 05-28-2012, 10:01 PM   #15
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Why does this switch need to be adjustable?
If you are using an adjustable switch, must you install a brake pressure guage?
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 05-28-2012, 10:15 PM   #16
KRatcliff
Liked 534 Times in 143 Posts
Adjustable helps you adjust your reaction time. There is a point of diminishing return. I don't use a pressure gauge, but I always check it for muscle memory right before I pre-stage.
KRatcliff is offline   Reply With Quote
Old 05-29-2012, 01:43 PM   #17
Dean Feiock
OK, then let me ask this.
Is it required that the pressure switch be installed before the line lock on the front brakes?
It would seem to me that installation after the line lock would circumvent the "two step applied by brake" rule. If you install it after the line lock, all you would need to do is step on the brake, apply the line lock, and the line lock pressure would hold the front brakes and the two step pressure switch closed. And we all know the line lock switch can be mounted any place you desire.
Old 05-29-2012, 04:03 PM   #18
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
i have found a very good quality pressure switch through my hydraulic company. it is adjustable and has both n/o and n/c polls, and is setup with a hershman type connector. It has a 1/4 npt nipple. not for the faint hearted if you think its gonna be cheap tho! it runs right around $60 each. i plan on using mine for nothing other than connecting a ground to a red warning light that tells me i have my pedal down to the same location each time in my foot brake stocker. i run a button on my pedal for the two step. i have bursted a brake line at the starting line once and was able to win the round cause the car didnt launch till i wanted it to (the other guy went red behind me!). with a pressure switch in the system opperating the two step the car would have taken off as soon as the pressure dropped.
just my two sense!
Ian
Ian Hill is offline   Reply With Quote
Old 05-29-2012, 04:05 PM   #19
Robert Simpson
Liked 20 Times in 12 Posts
Talking Re: Brake pressure switch
Dean, how I am going to do mine is install it between the master cylinder and the line lock. This way when the line lock is applied the pressure switch will not be applied. Lastly, I am putting a switch on the shifter that is in series with the pressure switch, it will only complete the circuit when the shifter is in low gear so that when I am going down track and need to apply the brakes it will not activate the two step. I have seen people put this switch on a toggel to turn it off when in high gear. But I run allot of 1/8 mile and things happen real quick and it is just one more thing for me to foget to do..LOL...Hope this helps
Robert Simpson is offline   Reply With Quote
Old 05-29-2012, 11:18 PM   #20
Dean Feiock
just my two sense!
Ian
Ian, that's how I have mine installed. When the rule changed, I removed my button from the console and installed it in the pedal.
No special switch, no concern over installing in front or rear hydraulics, no concern over front to rear bias, and no pressure guage.
Just step on the brake and simultaneously activate the switch.
