Liked 22 Times in 22 Posts
Can you use the same rings when you do a quick ball hone before reasembly? Only three pulls on motor. What grit ball hone?
don,t have one |
Liked 1,851 Times in 418 Posts
Randy, yes, you can do that, if the rings do not have a problem.
The best ball hone you'll find available quickly would be a 320 grit, you shouldn't need but a few passes, unless the cylinders are really screwed up. Brush Research makes the best ball hones, that's all I ever use, with their hone oil. I use a special version that is 1000 grit levigated aluminum to finish cylinders. I do have a 320 grit I use first on a "freshen up".
Alan Roehrich 212A G/S |
Thanks Allen. They shoudn't be in bad shape, I did the 14 gegree motor for a tractor puller, and at high rpm it blew the O ring on the filter, and I'm changing bearings, and thought I'd hit it quick. I've heard it doesn't hurt, and usually helps, so I thought I'd try it. It has .043 and 1.5 napier, and 3 mm. Is 320 OK?
don,t have one |
Do you torque plate before you hone with a ball?
don,t have one |
Ball hones are really for "surface conditioning", a 320 grit or finer ball hone really won't remove metal, unless you just hone on the block all day. You shouldn't need a torque plate, I do not use one when I ball hone.
Thank you Allen. You have been most helpful.
don,t have one |
I guess I could at least spell your name right. Sorry Alan. Also, what exactly is the material of the ball hone to order? There are so many different materials
don,t have one |
#8 | |
Randy, I'm used to people doing that, no worries. The standard 320 abrasive is fine for "freshen up" honing. The people at Brush Research are real good about getting you what you need. Alternatively, call who ever supplies your rings (I get mine from Keith Jones at Total Seal) and have them tell you what abrasive they like. I usually get one a little bigger than the bore size I plan to use it on, maybe by 1/8". I use my 1/2" cordless drill to run it, and use a fair amount of the Brush Research hone oil. You need to really scrub the cylinders afterward, and the slurry from the hone will be everywhere. I use "purple power" cleaner, cut about 50/50, and scrub with bore brushes and hot water. Wipe it clean with a white lint free cloth, if the cloth doesn't stay white, wash the block again. Wipe it down with a lint free cloth saturated in Dexron.
Thanks Alan. And the rings are total seal, and they said just hit with a 320. I will make sure the block is clean. Thanks again.
don,t have one |
Banned
Anyone ever tried coating the bores with hand cleaner the use a soft brush run by your drill? It works real well. Then pressure wash.
