Liked 165 Times in 59 Posts
looking to install the input shaft sensor on a jerico trans,but the issue is i do not have any room to install the sensor between the throw out bearing and the bearing retainer ,,has anyone had this issue??? i also have the shortest throw bearing i could find gmonde
Liked 1,892 Times in 423 Posts
Most systems don't install an input shaft sensor. They use engine RPM, and a drive shaft speed sensor. Then, using the gear ratio in the transmission for each gear, they can calculate clutch slippage. It eliminates the problems you're dealing with. You really don't want a sensor and the attending wiring in there, for several reasons.
Alan Roehrich 212A G/S |
#3 | |
Liked 6 Times in 2 Posts
Dale Posnick |
#4 | |
Liked 797 Times in 165 Posts
Search here in the tech section and you will find it i believe, you don't need the 1:1 if your data system can apply a ratio to the graph, which some can I am told. just apply the head set ratio and put the sensor on the counter shaft. The problem is that the bellhousings in stock are not as deep as let say pro stock and they can get the sensor in there easily. Last I knew they used sensors on the input in pro stock,
Dave Casey 1330 STK |
#6 | |
#7 | |
http://classracer.com/classforum/sho...ghlight=jerico
Dale Posnick Last edited by Dinsdale; 06-24-2012 at 03:57 PM. |
#8 | |
