Old 07-01-2012, 12:49 AM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Ring & Pinion Lube
What is the best grease to use in a Stocker rear? Jim
Old 07-01-2012, 02:27 AM   #2
Liked 1,878 Times in 422 Posts
Default Re: Ring & Pinion Lube
Richmond blue synthetic.
Old 07-01-2012, 07:29 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Ring & Pinion Lube
I've been using Amsoil Severe Gear 75w-90 for many years and have been happy with the results. It's in my Dodge dually also.
Old 07-01-2012, 08:24 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
For about three years I have been experimenting with Lucas products. I thought since Lucas is such a positive company for drag racing I would try the products.
So far I am very happy. My 12 bolt rear with 5.38 gears look like new after 150 runs. The 4.57 gears in 9" are the same. Engine bearings in a 408 SBC and 496 BBC are perfect. Two different powerglides look great after a full season.
I use the following Lucas products
*20w/50 "Plus" engine oil
*Semi-synthetic assembly lube
*Semi-synthetic ATF
and to answer your question about rear gear oil
*HD 80w90
I am satisfied Lucas is a good company with good products. It may require some shopping but can usually be bought at competitive pricing.
Larry Woodfin 471W
Old 07-02-2012, 11:17 AM   #5
Mile High
Pick your favorite brand and use their synthetic gear lube. I've been using synthetic for years. No big warm up procedure, it's ready to go.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 07-02-2012, 05:03 PM   #6
Walt Reynolds
Walt Reynolds's Avatar
I switched to Strange US Gear 5.38 for Dragweek 2011. The tech guys at Strange said do not use any Synthetic Lube. They recomended Lucas. This was the first time on Dragweek that I didn't screw up a ring and pinion.
Walt Reynolds is offline   Reply With Quote
Old 07-02-2012, 05:16 PM   #7
Michael Compton
Liked 59 Times in 13 Posts
I use the Joe Gibbs 75W110 in my Ford 9". Came highly recommended from Wayne @ Indy Gear. So far so good!
Michael Compton is offline   Reply With Quote
Old 07-02-2012, 05:21 PM   #8
randy wilson
Liked 22 Times in 22 Posts
I use one quart good synthetic, 1\2 quart synthetic auto fluid, and a pint of problend. It's a 5 speed unit, and mark williams center, with over 100 runs, 0 problems. Just me, and might not work for others.
don,t have one
Old 07-03-2012, 08:25 AM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Jim,
I have Mobile 1 synthetic in mine. So many runs I cant remember when I put the last ring and pinion in the car. I have also used Valvoline synthetic as well with similar results. I have a dana though.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 07-04-2012, 11:31 PM   #10
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Been using nothing but Mobil 1 synthetic gear lube for the past 2 decades. Current Richmond Pro R&P in my 9" with a MW "Pro Stock Assembly" 3rd member have 720 passes on them, 60 footing low 1.20s to high 1 teens.
