Old 06-30-2012, 07:04 PM   #11
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Engine Chill Down Unit
Originally Posted by Joe DeMarzo View Post
Tony are you comfortable sharing how much you picked up using the "cooler"? Inquiring minds want to know.
joe :i have heard 1 tenth just with chiller ,it also depends on how hot the conditions are to get the best out of the conditions ,,, gmonde
Old 06-30-2012, 07:50 PM   #12
John Brimer
John Brimer's Avatar
Liked 9 Times in 4 Posts
Just purchased one from Twist & Shout Racing. Advertised in dragster. Also, I have know Paul Pittman for over 20 years. The unit is insulated, powdercoated, 110 volt, with top shelf hoses and connections. The unit is $1,250 plus the in hose fitting. You need to ask him which one is needed for your application.
Phone number 612-281-3442
I have not used it yet, but when I cool with ice, I pick up et.
John Brimer is offline   Reply With Quote
Old 06-30-2012, 11:14 PM   #13
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
X2 on that
mat H/SA is offline   Reply With Quote
Old 07-01-2012, 02:40 AM   #14
69Cobra
Liked 2 Times in 2 Posts
Does this one have to have ice to cool?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 07-01-2012, 02:46 AM   #15
69Cobra
Originally Posted by Notch1320 View Post
Rob Youngblood at Advanced Clutches sells an affordable chiller.
Is this an actual chiller that doesn't use ice or just another circulator?
Kris Rachford
C/S 3032
Old 07-01-2012, 04:40 PM   #16
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
To answer Matt, Garrett and Joe D., I thought it was worth .07 at the Dutch Classic last year, but only about .03 or .04 at the Atco National Open in May of this year. Those are the only two times I've used it in competition. But this is only based upon what my prediction software thought it should have run, based on prior heads-up tests.
With ice water I can get the out-coming water down to about 70-75 degrees, while keeping the oil hot, using about 5 gallons of water and 2 large bags of ice.
Getting any cooler takes much longer, not to mention a couple of fresh loads of ice. And then when you cool it too long, you start to see the oil cool down, which is not what you want.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 07-01-2012, 04:49 PM   #17
Tony Curcio
Originally Posted by Chad Rhodes View Post
got a number for that check valve? I live in a part of the country that doesn't have basements, so I'm pretty clueless on those.
The label says Parts 2 O, part number appears to be FP0026-10. I found it in stock at Home Depot. It will fit inside 1 1/4" and 1 1/2" hoses.
Old 07-01-2012, 05:17 PM   #18
Chad Rhodes
Thanks tony
Chad Rhodes 2113 I/SA
