Old 07-02-2012, 10:19 AM   #21
randy wilson
Liked 22 Times in 22 Posts
Default Re: another egine miss
Thanks Ralph, didn't think of that. Was a little lean.
don,t have one
Old 07-02-2012, 11:32 AM   #22
Michael Compton
Liked 59 Times in 13 Posts
Default Re: another engine miss
When I had a miss, mine was at the top of high gear and you could hear the miss and see it on the racepak graph. It was crazy. Turns out we had a regulator and fuel pump going south. When under extreme load, the regulator and pump were causing flucuations in the fuel and making the motor miss because of no fuel. Might be something to check out.
Michael Compton is offline   Reply With Quote
Old 07-02-2012, 12:09 PM   #23
randy wilson
Thank you! Will do. The fuel pressure on the graph never flucuated though.
don,t have one
Old 07-02-2012, 01:20 PM   #24
FED 387
Liked 334 Times in 181 Posts
just remember that there is a difference between volume and pressure!!!! FED387
Old 07-02-2012, 01:57 PM   #25
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
FED 87 hit the nail on the head! I had the same thing happen this year at Great Bend. Data logger showed no fluctuation in fuel pressure, I pulled the fuel filter to see if that would make a difference. None. My engine builder suggested it was probably the pump. I replaced the pump, and checked calibration of fuel pressure sensor, it was within .5 PSI of a calibrated instrument. Next time out my car was back to normal.
Good luck
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-02-2012, 02:13 PM   #26
buzzinhalfdozen
Liked 11 Times in 8 Posts
I would agree with the fuel pump theory, he should see EGT's or O2 readings spiking if this is the case. Though EGT's are slow to resond you should see a corresponding increase (perhaps delayed a bit) when your issue arises. If using O2's (which are for the most part MUCH faster) you should see it go almost dead lean during the misfire event, as the AFR needs to depart from normal quite a bit to induce a misfire. The part I can't get over is he states that the tach and datalogger RPM "jump around" normally this does not happen with a fuel induced misfire the RPM's simply flatten out. Joe
Joe Buchanan SS/BX 3117
Old 07-02-2012, 04:57 PM   #27
randy wilson
Brand new pump, used one weekend at KCIR, before and never missed. Not saying this is not it, but doubtful. Did not have exhaust temperatures hooked up, just enstalled for the first time, but plugs looked real lean. Switched from C14 to C25, And jetted up 4 sizes, was that close?
don,t have one
Old 07-02-2012, 06:56 PM   #28
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Most likely tach jumping is ign.related miss.
Mike Taylor3601
Old 07-02-2012, 07:12 PM   #29
Ed Wright
Ed Wright's Avatar
Mine was missing intermittently in each gear at Joliet this past weekend. Felt like a leaky plug wire or plug. My plug wires are over due. Shouldn't run them more than 2 seasons. I usually put new plug wires on mine every winter. Gotten lax about it, and think it bit me. Bottom of the gears makes me think of plug wires if it has had the plugs changed.
Ed Wright 4156 SS/JA
Old 07-03-2012, 11:45 AM   #30
randy wilson
I agree Mike, ignition. But that only narrows it down so much. But thanks guys, will run the tester on it, and tell you what we come up with.
don,t have one
