Old 06-20-2007, 12:50 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Distributor Question
My son (18) finished building his 327 for his 70 Nova. It should run in the 11's. It has all good pieces in it but he put the factory distributor from the old 350 back in it with new points,condensor,etc. It has a curve kit in it with the heavy springs. The engine runs great at idle but at around 3000 it starts to break up and miss alot. If you really start to get on the engine it pops like crazy. I run a crank trigger in mine so we can't switch out and try it. is he going to need to run a msd or mallory type dist with this engine. Also he bought a standard coil. Im not sure if it can put enough juice for this engine. Thanks as always for the info.
Ed Carpenter
66 Chevy II
SS/H
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-20-2007, 05:58 PM   #2
Chip THELEGEND Johnson
Liked 281 Times in 79 Posts
Default
Ed,
Look on the parts for sale. I have a complete Mallory set up. Dist,ignition box and coil. i will make you a deal on it.
Chip
Chip Johnson
Chip THELEGEND Johnson is offline   Reply With Quote
Old 06-20-2007, 10:36 PM   #3
FED 387
Liked 333 Times in 180 Posts
Default
Use the mallory 102X points if still available will let you rev to 8500++++ otherwise go to an electronic ignition get rid of the points etc.
Old 06-21-2007, 12:47 AM   #4
Bruce Fulper
Liked 54 Times in 33 Posts
Default
Ed:
Get rid of those heavy springs. You want the total in early, say by 2500 rpm. Best buy is an MSD dist. f you want detail Email me.
Sometimes the best substitue for brains is silence.
Bruce Fulper is offline   Reply With Quote
Old 06-21-2007, 06:16 PM   #5
a2race
a2race's Avatar
Default
i have a brand new HEI from Summit that im not using, even has a pigtail for BATT+. would sell it for $135 + shipping.
adam
a2race is offline   Reply With Quote
Old 06-26-2007, 01:31 AM   #6
Bob Berleen
Default ballast resistor?
it sounds like the factory ballast resistor may have been bypassed in the wireing some chevys are at the old style voltage regulator and a swap to a one wire alternator may eliminate it . you might try adding an aftermarket
ballast resistor
Bob Berleen 6910 STK
65 Bel Air Wagon
P/SA 6910
ET 691Q
Bob Berleen is offline   Reply With Quote
