Old 07-19-2012, 02:32 AM   #11
Rory McNeil
Default Re: 72 Maverick
Originally Posted by treessavoy View Post
This is for you Maverick guys: Did Ford ever put a 4 speed behind it's 6cyl engines in a Mavericks?
JimR
No 4 speed available for the Maverick or Comet, 3 speed manual or automatic only. As for Maverick Stockers, Steve Horton from Washington State races a 73 Maverick 302 in R/SA, in fact he was at the Woodburn Oregon LODRS race last weekend. There have been at least 4 different 302 2 barrel Maverick & Comet Stockers in Div. 6 in the past few years.
NHRA 6390 STK
M/S 85 Mustang
Old 07-19-2012, 08:00 AM   #12
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Thanks guys, you have been a big help.
Thanks Mark. I will be talking to ya. I know you would be a BIG help.
Old 07-19-2012, 09:56 AM   #13
RJ Sledge
Liked 292 Times in 92 Posts
Ford put a 4 speed transmission in the later model 75-77(?) models, 4th gear was not a 1:1 drive ratio something like .85:1 overdrive, which was the going thing back then. The F100 and F150 had the same setup and those transmissions look like a 4 speed top loader but with different gear ratios. A lot of people are putting that setup in Cruisers and older Muscle cars. I have done 3 or 4. JPT turned me on th them, just getting harder to find good cores.
RJ
RJ Sledge is offline   Reply With Quote
Old 07-19-2012, 01:07 PM   #14
Rory McNeil
RJ
Ford put the 3 speed overdrive "Orion" toploader in Granadas and Monarchs, as well as light duty pickups and vans, but I`ve never heard of one in a Maverick.
NHRA 6390 STK
M/S 85 Mustang
Old 07-19-2012, 05:37 PM   #15
mtkawboy
Liked 54 Times in 18 Posts
Early Falcons , 63-65 era, had a Dagenham 4 speed behind the 170 6 cylinders. The OD 4 speed toploaders drove thru the cluster in overdrive and arent real strong. The weakest have bushings on the cluster & the better ones {used in vans }have needle bearings. Doesnt mean you have to run the original one though. I meant for street use
mtkawboy is offline   Reply With Quote
Old 07-19-2012, 05:44 PM   #16
David Lee
Liked 346 Times in 126 Posts
Here is the specs for all mavericks for all years
http://www.fordmaverick.com/yrtoyr.htm
Old 07-19-2012, 07:52 PM   #17
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
RJ
wouldn't that make 'em a 4speed?
btw, those od trans' are getting scarce to find parts for...
Old 07-20-2012, 08:47 AM   #18
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
As someone said, the maverick will be tough in stock with the 2bbl which is why we went with Super Stock. We put a clone 289/210/210 motor in Jamie Schoenly's '72 Maverick here in D1 from spare parts lying around from my 289. It's not far under the index yet but it is a cool looking super stocker! I've never really looked into EFI combos, that's an idea..
Robbie is from Phoenix, so IHRA isn't a viable option..I'm sure he'd like to race at Firebird Nat's and Div's.
The 2 bbl 302 is okay here during the winter months anyway.
I would suggest building it as a good 9" tire car, but then use a low rated EFI combo for Super Stock, where you can use a transbrake.
There is a nice one in Div 1 done similarly.
Robbie, call or write if you want
602-769-0346
markyac@cox.net
'65 Mustang SS/L & L/SA
Old 07-20-2012, 10:15 AM   #19
BlueOval Ralph
Banned
How about a Maverick with a Boss 302 got GT? A 351 C would be fast but won't clear spring towers and get a good set of headers on it.
BlueOval Ralph is offline   Reply With Quote
